06-25-2007, 04:28 PM
Post: #351
i would love to hear more about that greddy when you hav tryed it:.)
06-26-2007, 07:40 PM
Post: #352
Omg that looks pretty bad! Banging head
What are you going to do now?
Repair the block and put new pistons with bigger pistonrings in oder a new motor? Or is the damage on the cylinderwalls to big to hone the block?
I hope you get the car back on the road very soon Wink
06-27-2007, 01:33 AM
Post: #353
Hone the block, wiseco pistons, balance crankshaft with flywheel, pulley and pressure plate...
The whole thing
06-27-2007, 01:42 AM
Post: #354
a gze would do the same thing..that engine be some job when u get it buillt.. that car is workin hard to do that damage lad.. keep it up
DONT JUST BREAK DA RULES...
RULE DA BENDS...
FUN AINT IN A STRAIGHT LINE!!!
07-02-2007, 10:57 AM
Post: #355
Wow - nice suspension.. If may I ask - how much? Smile)
IF Carlsberg made an AE86, then it would be propably the best car in the world...
07-02-2007, 12:48 PM
Post: #356
apardal if you want the best bottom end you should try and grasp the lower block of a 20v silertop.
Then order the rebuild kit (pistons etc) from sym for 256 dollars. Rebuild it to a 16v and you'll have the strongest bottom you can get.
Only bad thing would be is that its less revvy due to a slightly thicker crank and rods. But with your flywheel you should correct that again.
07-02-2007, 02:04 PM
Post: #357
Incredible build.
I just love to watch these come together from the shell and then be used! Seems to make the whole thing that much better.
really great work. Thumbs up!
07-03-2007, 01:36 AM
Post: #358
woper, the suspension got to a total of nearly 1400€ including shipping and taxes.
robokill, the engine is being rebuilt with new bearings, and ARP fasteners that should keep things together, preventing damage to these bearings.
The pistons are going to be new, and the block bored. You're right. I would be better off with a 20v block/crank, but I'm really sceptic about importing used parted stuff.
Best regards
07-03-2007, 03:29 AM
Post: #359
What head studs are you ganna use?
If you want to play safe, i think its wise to replace those 20 yo studs considering the gear ratio you reached, there is a arp kit for the head too.
[Image: AEU86 AE86 - Corolla Levin Repair, Paint...WITH VIDEO]
Cump´s
Filipe Oliveira
07-03-2007, 08:03 AM
Post: #360
Lipinhu Wrote:What head studs are you ganna use?
i think he is gonna use ARP stud kit. good choice. Thumbs up!
really sweet build, simple and clean. big thumbs up.
good luck on the engine.
te72 wagon
ae86 levin coupe project
  Toyota Corolla AE86 LEVIN ( Poland) sylwekgtir 40 54,043 11-23-2018 10:13 PM
Last Post: sylwekgtir
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 14,742 10-07-2018 09:45 PM
  RaceMinded satin black Toyota Corolla AE86 Levin Coupe RaceMinded 22 30,903 09-02-2010 07:25 PM
Last Post: Apolan
  Shell make over a coat of paint williep12 4 6,949 02-01-2010 03:52 PM
Last Post: Kid Karola
  Repair/ Body whitepoint 6 8,203 03-12-2008 09:21 PM
Last Post: whitepoint
