Crankshaft oil seal - help!
05-03-2007, 10:12 AM
Please help!
I need dimensions of front crankshaft oil seal. They are giving me 3 different dimensions in the store: 35/49/6 or 32/49/6 or 32.5/46/6. I have red top, big port, 7 ribs engine. Fun is not the straight line! |
05-03-2007, 10:56 AM
Never mind, I've just ordred it directly from toyota for 9€.
05-03-2007, 01:32 PM
max_ae86 Wrote:Never mind, I've just ordred it directly from toyota for 9€. Toyota Bacic, 70kn !? I need one of those, mine it's leeking heavy .. Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
05-10-2007, 12:27 PM
I'm planning to replace the seal this weekend, so I need more info about this job.
Work steps and tools required? Thx. Fun is not the straight line! |
05-10-2007, 03:00 PM
max_ae86 Wrote:I'm planning to replace the seal this weekend, so I need more info about this job. Manual meybi... ![]() Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
05-14-2007, 10:25 AM
Out with the radiator
Off with the accessory belts Off with the top timing belt covers Off with the crank pulley Off with the lower timing belt cover Off with the timing belt and timing belt drive pulley Out with the old seal and clean the surfaces In with the new seal (with a smear of GP grease on the rubbing face) Reverse the above to assemble Make sure you : Mark the position of the timing belt on the pulleys, so that you don't mess up the timing. Put the timing belt around the bottom driving pulley before you replace the crank pulley ![]() Have the correct tools and some patience, as the crank pulley can be a bit difficult to get off, and needs to be torqued up properly on assembly. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
Crankshaft stamping | Blaze0010 | 6 | 1,481 |
06-10-2024 10:16 PM Last Post: Blaze0010 |
Oil leaks - Help | Bojack | 4 | 5,704 |
10-19-2018 01:34 PM Last Post: Dave W |
Exhaust fumes in cabin (Hatch seal problem!) | Lt86 | 16 | 20,662 |
11-13-2015 01:20 PM Last Post: pack |
trans oil, lsd oil change | Apolan | 9 | 17,315 |
Crank seal | TheGerman | 8 | 10,945 |
04-12-2014 09:36 AM Last Post: Apsogos |
