Crankshaft problem and what i need?
06-06-2008, 05:16 PM
The 20v chrankshaft will fit to 16v model with 40mm diameter of connection rods? i need the pistons but i only found with 20mm pin my is 19
06-06-2008, 05:41 PM
pernati Wrote:The 20v chrankshaft will fit to 16v model with 40mm diameter of connection rods?
no... the rod journals for both 20V engines is 42mm
pernati Wrote:i need the pistons but i only found with 20mm pin my is 19
You have 19mm wrist pins?? Do you have a photo of the pistons??
Dan -
06-13-2008, 11:23 PM
TRD are 19 mm pistons are you sure?
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  Crankshaft stamping Blaze0010 6 3,350 06-10-2024 10:16 PM
Last Post: Blaze0010
  Which new bearings for ae101 4AGZE crankshaft&connecting ditn 4 8,694 10-31-2013 06:04 PM
Last Post: ditn
  4agZe problem solved - 99% IC problem Okami 41 45,077 07-12-2012 04:49 PM
Last Post: Okami
  Maybe problem with TRD shock absorber and springs Mattolo 22 26,241 10-15-2011 07:40 PM
Last Post: zenki
  crankshaft timing belt pulley won't come off Dino86 8 11,384 02-21-2011 02:05 PM
Last Post: Project D
