crankshaft timing belt pulley won't come off
02-16-2011, 10:43 PM
Hello,
I have to replace the crankshaft oil seal on the timing belt side. All is removed except the timing belt pulley (not the one for the alternator belt). It just refuses to come off. If I'm correct it should just slide off right? I emptied almost one full can of WD40 on it but still it doesn't move at all. Do I miss something here? What supsosed to be a 2hrs job last already 2 days now and I want to register the car ASAP Any advise? Thanks. |
02-17-2011, 01:03 AM
| crankshaft timing belt pulley won't come off | |||
02-17-2011, 07:35 AM
recently I had one so bad that I had to cut it length wise, almost all the way down to the crank with a Dremel, and then I had to split it to get it off
Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-17-2011, 12:32 PM
I drilled the shit out of it, then hammered it till it fall into two pieces
AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
02-17-2011, 12:40 PM
hmm.. doesn't look promising...
First I will try the 3 arm puller than the hammering and cutting... |
02-19-2011, 04:15 PM
VICTORY
Finally heating, and the 3-arm pulley did the trick plus additional hammering and swearing :wink: Not only the bodywork seems sensitive for rust |
02-21-2011, 01:29 PM
Hehe
I removed one yesterday, it came off by hand. No tools needed http://monkeymagic86.wordpress.com |
02-21-2011, 02:05 PM
Nomuken Wrote:Hehewhen the crankshaft is mint yes you don't need any tool, but after 20years in wet conditions it's totally different
| idler pulley for 4AGE with power steering/aircon | ondafly | 4 | 947 |
07-06-2026 11:11 PM Last Post: ondafly |
| Crankshaft stamping | Blaze0010 | 6 | 4,520 |
06-10-2024 10:16 PM Last Post: Blaze0010 |
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 18,623 |
| Won´t start | AlexKTM | 6 | 21,035 |
12-04-2017 10:05 PM Last Post: banpei |
| Rear Seat Belt Question | sleepercivic | 5 | 13,049 |
06-29-2017 09:30 PM Last Post: banpei |
