crankshaft timing belt pulley won't come off
02-16-2011, 10:43 PM
Hello,
I have to replace the crankshaft oil seal on the timing belt side.
All is removed except the timing belt pulley (not the one for the alternator belt). It just refuses to come off.
If I'm correct it should just slide off right?
I emptied almost one full can of WD40 on it but still it doesn't move at all.
Do I miss something here?
What supsosed to be a 2hrs job last already 2 days now and I want to register the car ASAP Sad
Any advise? Thanks.
02-17-2011, 01:03 AM
Here are a few tips...
http://www.toymods.org.au/forums/showthread.php?t=28800
Cheers... jondee86
02-17-2011, 07:35 AM
recently I had one so bad that I had to cut it length wise, almost all the way down to the crank with a Dremel, and then I had to split it to get it off Angry
Dan -
02-17-2011, 12:32 PM
I drilled the shit out of it, then hammered it till it fall into two pieces Big Grin Big Grin
AE86 GT - SR20DET BlackTop //// Trackday beater
Citroen C4 Coupe VTR - 1.6HDi //// Streetcar
02-17-2011, 12:40 PM
hmm.. doesn't look promising... Evil
First I will try the 3 arm puller than the hammering and cutting...
02-19-2011, 04:15 PM
VICTORY Thumbs up! Thumbs up!
Finally heating, and the 3-arm pulley did the trick plus additional hammering and swearing :wink:
Not only the bodywork seems sensitive for rust Huh
02-21-2011, 01:29 PM
Hehe
I removed one yesterday, it came off by hand. No tools needed
http://monkeymagic86.wordpress.com
02-21-2011, 02:05 PM
Nomuken Wrote:Hehe
when the crankshaft is mint yes you don't need any tool, but after 20years in wet conditions it's totally different Tongue
  Crankshaft stamping Blaze0010 6 1,704 06-10-2024 10:16 PM
Last Post: Blaze0010
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 14,229 07-18-2019 03:52 PM
Last Post: oldeskewltoy
  Won´t start AlexKTM 6 18,030 12-04-2017 10:05 PM
  Rear Seat Belt Question sleepercivic 5 10,410 06-29-2017 09:30 PM
  4agze timing leon205gti 11 14,252 04-07-2017 03:10 AM
Last Post: jondee86
User(s) browsing this thread:
