Daily/Drifter - 4AGZE
06-09-2010, 04:27 PM
Post: #71
Gtsi-R Wrote:nice slippers on the roof OMG hahaha I have slippers with me on warm days cuz like I said I cant stand the heat so then I slip on the wabaki to cool down some more. hahaha Some other people asked me if I had bolted or glued them on... people are insane! + stupid in the koo koo brain -DWG- Drift Wolf Gaming |
06-14-2010, 11:03 AM
Post: #72
WOOP WOOP! D2 Coilovers on this HO! AH YEAH!
LOL! Yesterday me and my friend where busy in his aircon cooled garage (thank God). I need more cold than heat before I go crazy. Eventho I was a lil bit sick and my friend was tired - we pulled through from 12:00 to 20:00 o clock. (we had to check some things - take regular breaks - and we also had a lot of visitors). Results VOOR-BEFORE NA-AFTER -DWG- Drift Wolf Gaming |
06-14-2010, 12:44 PM
Post: #73
Cool project, keep it the original colour please
06-14-2010, 08:31 PM
Post: #74
I fear you have virtually no more bump travel left in your car.
You do realize these coilovers are meant to be welded on in place of the original springperch, and that the struts most likely need to be shortened? Did the shocks fit the original strut or did you put some spacers in? If you feel it bottoming out a lot you should consider getting them mounted propery before you break those expensive shocks. FABRICA MI DIEM, PVNC! |
06-14-2010, 08:48 PM
Post: #75
Ik heb deze demper kit ook. en je hoeft niets te lassen of slijpen aan je schokdemper poot. maar ik weet wel dat je veel comfort kwijt ben.
maar wel een geweldige wegliging toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
06-14-2010, 09:08 PM
Post: #76
Thanks slow and Ivan...
Ivan - I have researched a bit and asked slowboy a lot about this set. The shock went in fine - even had to softly hammer them a bit down but it all fitted fine... the rear has a big head so it should be fine as well... the only problem is if you put the car on a bridge - the front springs will come loose a little big because of the distance... When you put the car back down again the wheels/weights presses them back again. That's all. Ive drove some km's now and havent found any problems. the only problem we encountered last night was a bearing (front right) needs to be fixed. -DWG- Drift Wolf Gaming |
06-14-2010, 09:25 PM
Post: #77
Maybe I'm mistaken about the K2 set then, thought it was short stroke with shorter shock lenght. Hammering them in does sound concerning though, every shock I've tried to date went in easy peasy.
When is it due for paint ? FABRICA MI DIEM, PVNC! |
06-14-2010, 11:51 PM
Post: #78
looks good..
great to see you managed to install them in 1 day time Cheers from the USA! Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
06-15-2010, 12:25 AM
Post: #79
@ Roel - are you in the usa? You bastard bring me some souvenirs hahaha
and thanks for the compliments man! Hope your doors are gonna turn out good!!! @ Ivan - I dont know my friend... I have to figure out who what and where -DWG- Drift Wolf Gaming |
07-26-2010, 10:28 PM
Post: #80
The weather changed last couple of days so I decided to do some cheap ass modding...
Painted the spoiler black... Painted the bumpers white... Made a special arm for my airfilter so its not hanging in the air anymore (no pics). And installed a simple roster grill for more air. Everything is still under construction. Next up: new brake pads etc. and I need to check the right front wheel cuz I think I might have a problem with a bearing but I dont know for sure. The white bumpers are ice-white but will soon tone down a bit and will blend with the fenders (same paint but earlier installed). no grill embleemloos grilleke -DWG- Drift Wolf Gaming |
The first luxembourgish drifter.... | KWRacing | 43 | 32,235 |
11-08-2007 06:24 PM Last Post: banpei |
Desert Drifter | Shinsaki7052 | 14 | 12,324 |
08-20-2006 05:36 AM Last Post: Shinsaki7052 |
