Diff goes click, clunk and donk
07-06-2005, 10:30 AM
Hey guys.
I have this clicking sound come from my diff area while I'm driving around. It normally happens will I am changing gear. I changed my diff oil the last night because I thought this would solve the problem but it didn't. I guess it means its dieing but I just want to be sure..any suggestions? I once read that you shouldnt believe everything you read. |
07-06-2005, 10:35 AM
Are you sure its the diff and not your gearbox? Sound can travel in mysterious ways you know
![]() Anyways, I have no idea what could cause this in a diff... Hope someone else knows... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
07-06-2005, 10:44 AM
It maybe the gearbox...I gear box has a slight wine sound while driving so I thing that, that is on its way out but I want it to last till I do my engine and transmission converson.
07-06-2005, 10:56 AM
couldn't it be that the joints from the axel to the diff are loosening a bit.
Because when you shift gear, the drive is 'lost' so for a while the rear axle drives the axle, then you are finished with shifting and then it's the other way around. If there is some space between the joints, it could make some sounds "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
07-06-2005, 11:20 AM
Good point. I shall have alook at that tomorrow when after work .
Cheers I once read that you shouldnt believe everything you read. |
| Click in steering column? | DJexor | 2 | 2,383 |
07-17-2023 08:26 PM Last Post: totta Crolla |
| Power steering clunk | Jezza_hr | 12 | 17,873 |
09-24-2021 01:42 PM Last Post: pack |
| Gearbox and Diff options | MIGGZFSU | 35 | 36,223 |
03-26-2017 12:00 AM Last Post: MIGGZFSU |
| Check battery light goes ON | MartinS | 23 | 26,463 |
02-14-2012 11:03 AM Last Post: jondee86 |
| What Diff Oil For a Clutch plate diff? | jamieae86 | 10 | 16,493 |
12-16-2011 11:14 AM Last Post: bakonick |
