Diff goes click, clunk and donk
07-06-2005, 10:30 AM
Hey guys.
I have this clicking sound come from my diff area while I'm driving around. It normally happens will I am changing gear. I changed my diff oil the last night because I thought this would solve the problem but it didn't.
I guess it means its dieing but I just want to be sure..any suggestions?
07-06-2005, 10:35 AM
Are you sure its the diff and not your gearbox? Sound can travel in mysterious ways you knowSmile
Anyways, I have no idea what could cause this in a diff... Hope someone else knows...
07-06-2005, 10:44 AM
It maybe the gearbox...I gear box has a slight wine sound while driving so I thing that, that is on its way out but I want it to last till I do my engine and transmission converson.
07-06-2005, 10:56 AM
couldn't it be that the joints from the axel to the diff are loosening a bit.
Because when you shift gear, the drive is 'lost' so for a while the rear axle drives the axle, then you are finished with shifting and then it's the other way around. If there is some space between the joints, it could make some sounds
07-06-2005, 11:20 AM
Good point. I shall have alook at that tomorrow when after work .
Cheers
  Click in steering column? DJexor 2 1,316 07-17-2023 08:26 PM
Last Post: totta Crolla
  Power steering clunk Jezza_hr 12 15,350 09-24-2021 01:42 PM
Last Post: pack
  Gearbox and Diff options MIGGZFSU 35 28,934 03-26-2017 12:00 AM
Last Post: MIGGZFSU
  Check battery light goes ON MartinS 23 22,562 02-14-2012 11:03 AM
Last Post: jondee86
  What Diff Oil For a Clutch plate diff? jamieae86 10 14,507 12-16-2011 11:14 AM
Last Post: bakonick
