Diff noise?
01-06-2008, 12:47 PM
Diff noise?
CW&P sounds stuffed... mine whines its head of as the gears are really worn..
20 year old gears tend to do that |
05-04-2009, 04:34 PM
Diff noise?
Well..it finally happened.
R&p is gone. It had been wining for over a year now. But nothing else. I was at a driftday sunday and had been drifting for 4 hours. It had been raining and the track was quite wet. Everything is going fine. We had a 1 hour break and then I went out on the track again. Did a couple of runs...still nothing strange going on. Then, next lap, take the first turn, clutchkick...and...crack!...just like that....all of a sudden. This is what it looks like: ![]() ![]() Pinion is missing a lot of teeth. The ring has a lot of broke teeth too. Notice how the are all broken off on one side only. Bad alligment? Or just old and worn? What do you guys think of it. I'm thinking about a 4.77 r&p with a solid spacer next. But I want to be sure that it's reliable! Any other suggestions/alternatives? PS. Engine is stock 120hp with a 2 year old stock replacement clutch. Clutch is holding up fine. |
05-04-2009, 05:20 PM
Diff noise?
allignment = 1 thing (if set correctly it has less chance of BANGING the R&P but you'll break it anyway becuase of clutch kicking.
The engine is turning and you are banging in power on something that is either standing still or running at completely diffrent speeds. It will never stay alive for that long. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
05-05-2009, 09:25 PM
Diff noise?
For sure a 4,7:1 with solid spacer is a good solution . Did it on my rally car with no problems for now .
Bought it from Weirperformance on this forum , very reliable and helpful seller . Check this link :http://www.aeu86.org/viewtopic/f-s-4_778...e86/t/7126 Phil Filh Save the RWD cars |
05-08-2009, 06:55 PM
Diff noise?
@filh: Yeah I'll probably contact spence for the r&p.
How did the install with the solid spacer go? Easy? I saw that I also have some play in the diff. Take a look at the vid: The pinion teeth are all gone, so the teeth of the ring aren't coming against anything. But I guess this still is too much play right? What do you guys think? |
05-08-2009, 07:16 PM
Diff noise?
wow,
It's completely loose, it should have no play at all ![]() 280z '75 audi S4 B5 '99 KE25 '71 |
05-08-2009, 11:13 PM
Diff noise?
No play allowed in that way .
If you buy from Spence , you'll get a full set with washer to fit the correct preload . You should also order a new bearing set ( 3pces). But if you never done such work , you'd better ask a good mechanic to do it . It 's a precision job .You'll need a comparator to fix the correct backlash. You'll get a Job description from Spence , but for confirmed mechanic . Regards Filh Filh Save the RWD cars |
TRD Short Shifter Rattle Noise, It's Normal? | Mattolo | 19 | 20,986 |
04-27-2024 10:04 PM Last Post: banpei |
Clicking noise from glove box | chrisae86 | 4 | 2,319 |
09-08-2022 11:36 PM Last Post: chrisae86 |
Noise Insulation for AE86 | decryphe | 1 | 4,255 |
11-03-2016 11:51 AM Last Post: mad.matt |
Whining noise HELP PLEASE | izanagi | 10 | 12,808 |
03-26-2015 06:48 PM Last Post: Komba |
Whining noise only in 4th & 5th. | izanagi | 7 | 11,214 |
09-25-2014 07:09 PM Last Post: Uzelac |
