Difference in Brake master cylinder
11-17-2010, 01:40 AM
Hey guys i want to ask if there is a difference between JDM Zenki or Kouki brake master cylinder as i know there is a difference in the clutch master cyl
thx
Alex
11-17-2010, 09:33 AM
I don't know if it's JDM Zenki and Kouki, but there are 2 and 4 bolt master cylinders in AE86's
http://monkeymagic86.wordpress.com
11-17-2010, 09:45 AM
2 bolts 13/16"
4 bolts 7/8"
11-17-2010, 12:24 PM
thx i will have a look at mine, also which other master cylinders are compatable to ae86 and is it worth upgrading when using stock brakes ?
11-17-2010, 12:36 PM
Stock MC is enough for stock brakes.
I've changed to RX7 4pot calipers and wasn't happy with it at all. Changed the MC for a Landcruiser one (1") and the difference was huuuge
11-17-2010, 12:54 PM
is a landcruser one plug and play ?
btw.. i've got the wilwood 4 piston kit on stock mbc with not much difference in pedal feel but waaaay more stopping power Smile
'87 levin coupé
[Image: AEU86 AE86 - Difference in Brake master cylinder]
11-17-2010, 01:34 PM
There is a difference beetween RHD and LHD brake master cylinders.
Regards
11-17-2010, 03:32 PM
For RHD:
http://www.hachiroku.com.au/blog/?p=2902
For LHD:
depend of wich one you have (2/4bolts)
Actualy many toyota have the same bolt pattern.
Take one from an heavier car Wink
11-18-2010, 01:05 AM
By any chance the ones from the AW11 mk1 mr2 fit ??? they look simular-ish
11-18-2010, 09:27 AM
I have 2 bolt vesrion (13/16") in mine (1984 model ZENKI) and my spare one is a 4bolt type (7/8") (from a 1986 model KOUKI).
Anyone can give me OE partnumber for both?
I like to buy a rebuild kit for them.
Is there any cheaper rebuild kit available than OE Toyota?
  Bigger brake master cylinder options Koen Bongers 6 660 12-03-2025 02:01 PM
Last Post: r.ave
  4AGE cylinder head plug removal Ivan141 5 3,900 09-30-2023 09:47 PM
  Axel anyway to tell the difference? MIGGZFSU 7 9,572 10-24-2017 08:48 PM
Last Post: MIGGZFSU
  Brake advice - master cylinder mannix20vt 12 17,620 08-21-2017 03:21 PM
Last Post: Project D
  Why Zenki and Kouki colour difference MIGGZFSU 10 22,671 04-23-2017 09:16 AM
Last Post: MIGGZFSU
