Difference in Brake master cylinder
11-17-2010, 01:40 AM
Hey guys i want to ask if there is a difference between JDM Zenki or Kouki brake master cylinder as i know there is a difference in the clutch master cyl
thx Alex |
11-17-2010, 09:33 AM
I don't know if it's JDM Zenki and Kouki, but there are 2 and 4 bolt master cylinders in AE86's
http://monkeymagic86.wordpress.com |
11-17-2010, 09:45 AM
2 bolts 13/16"
4 bolts 7/8" |
11-17-2010, 12:24 PM
thx i will have a look at mine, also which other master cylinders are compatable to ae86 and is it worth upgrading when using stock brakes ?
11-17-2010, 12:36 PM
Stock MC is enough for stock brakes.
I've changed to RX7 4pot calipers and wasn't happy with it at all. Changed the MC for a Landcruiser one (1") and the difference was huuuge http://monkeymagic86.wordpress.com |
11-17-2010, 12:54 PM
is a landcruser one plug and play ?
btw.. i've got the wilwood 4 piston kit on stock mbc with not much difference in pedal feel but waaaay more stopping power ![]() '87 levin coupé ![]() |
11-17-2010, 01:34 PM
There is a difference beetween RHD and LHD brake master cylinders.
Regards |
11-17-2010, 03:32 PM
For RHD:
http://www.hachiroku.com.au/blog/?p=2902 For LHD: depend of wich one you have (2/4bolts) Actualy many toyota have the same bolt pattern. Take one from an heavier car ![]() |
11-18-2010, 01:05 AM
By any chance the ones from the AW11 mk1 mr2 fit ??? they look simular-ish
11-18-2010, 09:27 AM
I have 2 bolt vesrion (13/16") in mine (1984 model ZENKI) and my spare one is a 4bolt type (7/8") (from a 1986 model KOUKI).
Anyone can give me OE partnumber for both? I like to buy a rebuild kit for them. Is there any cheaper rebuild kit available than OE Toyota? |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,207 |
Axel anyway to tell the difference? | MIGGZFSU | 7 | 7,966 |
10-24-2017 08:48 PM Last Post: MIGGZFSU |
Brake advice - master cylinder | mannix20vt | 12 | 14,447 |
Why Zenki and Kouki colour difference | MIGGZFSU | 10 | 19,450 |
04-23-2017 09:16 AM Last Post: MIGGZFSU |
Windshield difference | d3nso | 3 | 6,490 |
03-26-2016 02:21 AM Last Post: fax0815 |
