Difference in Brake master cylinder
11-18-2010, 03:05 PM
looks like i need the 2 bolt version as mine is a 1984 zenki model, anyone has one in gd condtion ?
11-19-2010, 07:52 PM
If you've removed the master cylinder, it's worth taking it down to your friendly local motor factor [when they're not too busy] and compare it with ones they have in stock.
Quite often the main cylinder body will be identical, but there may be different shape reservoirs or other fittings for different models. Just swap the detachable parts from your old one, if need be.
47201-12340 RHD 8305-8505 NISSIN or JKC
47201-12500 RHD 8508-8704 AISIN 13/16in
47201-12370 LHD 8305-8505
47201-12460 LHD 8305-8707
47201-12510 LHD 8508-8704
Other FWD Corollas etc might be a good place to start. An AE92 clutch master cylinder can be easily modded to fit the AE86.
http://www.AE86imports.0catch.com
  4AGE cylinder head plug removal Ivan141 5 2,209 09-30-2023 09:47 PM
  Axel anyway to tell the difference? MIGGZFSU 7 7,969 10-24-2017 08:48 PM
Last Post: MIGGZFSU
  Brake advice - master cylinder mannix20vt 12 14,459 08-21-2017 03:21 PM
Last Post: Project D
  Why Zenki and Kouki colour difference MIGGZFSU 10 19,471 04-23-2017 09:16 AM
Last Post: MIGGZFSU
  Windshield difference d3nso 3 6,494 03-26-2016 02:21 AM
Last Post: fax0815
