Differences between modelyears
09-16-2004, 11:54 AM
Like Widar already said in another topic, there are quite a few differences between the modelyears.
Wouldn't it be interesting to see if we could make a complete list of all the differences? If I take a look at my cars I see differences in front- and rearbumper, sideskirts, the black strips on the headlights, grille, interior clothing, sidemarkers etc. etc.
Does anyone know all the differences?
09-16-2004, 12:13 PM
The grill are different, as well as some mechanical parts, LSD and on.
Dunno exactly though. The Toyota parts CD should have it all listed?
Best Regards,
[Image: AEU86 AE86 - Differences between modelyears]
09-16-2004, 12:26 PM
Good luck figuring out differences using the EPC cd's...
These are some differences I know of:
-Bumpers & bumperlips
-Spoiler on bootlid (zenki=rubber, kouki=plastic)
-Sideskirts (zenki are WAAAAYYYY cooler...think I'll try making FRP copy's of senna's sideskirts)
-Fender trimming on late models (rust provoking plastic junk)
-Grilles: louvre and pop-up grille are zenki, closed plastic is kouki
-Interiors..asides from color scheme and fabric, the kouki door panels have fabric on them, zenki are all plastic.
-Wiring loom: Just look at the check engine connectors...theyre different.
-Master brake cilinder: according to dreamsofdrifting.com (migs website) the kouki MBC is of a slightly better design.
-Headlights and clearance lights: Different mounts and metal/plastic trimmings on kouki models..also on european models zenki has black side indicators.
-Rear axles and LSD
10-07-2004, 10:49 PM
Not forgetting the wheight of the car and the options
New model is available with power sunroof (haven't seen old version original with that)
and most important the weight
as i own one old and one new model
old model weighs around
936
new one
976
and in the netherlands thats bad for you caus the goverment lets you pay more :-(
  Clutch differences LUK vs Exedy r.ave 2 5,222 05-27-2021 09:30 AM
Last Post: r.ave
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 7,096 07-31-2019 11:28 AM
  4AGE block differences explained (incl. some eyecandy) Bean 46 89,327 05-05-2019 04:03 AM
Last Post: Rocker100
  Decently heavy vibration in fourth gear between 2000-2300rpm dinkers542 4 5,694 11-29-2014 12:27 AM
Last Post: dinkers542
  Change the meter between zenki and kouki T_AE86 9 10,721 12-03-2012 03:13 PM
Last Post: T_AE86
