Different RNP types (SR5 open/GTS open/GTS LSD)
03-14-2007, 10:49 PM
What does it matter if its an open diff or an lsd?
![]() ![]() Dorito just needs the Ring & Pinion... danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
03-15-2007, 01:17 AM
Arent they?
They fit in the same housing dont they? Maybe I m mistaken, plz correct me if I m wrong ![]() ![]() danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
03-15-2007, 01:23 AM
Just SR5 one is non-compatible.
03-15-2007, 03:45 AM
It's compatible. There's just no need to disassemble cw and p since I got an all new housing with my 4.78 I'd sell you mine with the original dif ratio...that's why I stated "open diff". As such, there would be no need to fine-tune the diff for tolerances too.
Regards, Bruno Belo |
03-15-2007, 08:03 AM
I don't get this. If your cwp is on an open diff, that would make it an SR5 diff meaning I cannot use the cwp. Right?
03-15-2007, 10:01 AM
Dorito86 Wrote:I don't get this. If your cwp is on an open diff, that would make it an SR5 diff meaning I cannot use the cwp. Right? No. Some GTS use open diff (and all SR5 too, but SR5 one is little different). All GTS crown/pinion combos are compatibles in GTS rear end. There is an issue about compatibility of open diff (GTS) halfshafts only - they must be shortened in order to work with LSD diff (GTS). But crown/pinions are compatible. In short - you can use any CWP coming from GTS. You can't use SR5 CWP. |
03-15-2007, 12:00 PM
So question is, is Bruno's diff from an SR5 or from GTS?
Mux, maybe we should move this talk somewhere else instead of ruining this thread. danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
03-15-2007, 12:46 PM
nmwisima Wrote:Mux, maybe we should move this talk somewhere else instead of ruining this thread.Good point, interesting information for later on aswell, what RNPs fit what axles (SR5 v.s. GTS) Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
03-15-2007, 05:14 PM
SR5 ring gear measures 6.3", GTS ring gear measures 6.7" The only company I know of who made(not sure they still have it.....) a LSD for the smaller 6.3" ring and pinion is/was Cusco
*IF* you use a complete assembly.... you have to be careful of zenki/kouki differences. The one significant different is the axles splines are different from zenki to kouki, so you need the correct axles to fit the spider gears(in an open diff) or the LSD splines in a LSD diff Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-19-2007, 11:15 PM
oldeskewltoy Wrote:SR5 ring gear measures 6.3", GTS ring gear measures 6.7" The only company I know of who made(not sure they still have it.....) a LSD for the smaller 6.3" ring and pinion is/was Cusco Is there not an SR5 with a 6.7" rear end in the USA then? Did the US get a 10-bolt pumpkin drum brake rear end? All 10-bolt pumpkins are 6.7" cw&p. |
rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 3,501 |
07-25-2021 04:41 AM Last Post: Bean |
Anyone farmiliar with hks camshaft types for 4age? | spill86 | 5 | 16,235 |
11-18-2017 11:36 PM Last Post: oldeskewltoy |
Using a different diff in an AE86 | megabob | 6 | 8,577 |
02-17-2015 03:37 PM Last Post: megabob |
where to start on sr5-GTS swap | dinkers542 | 0 | 3,336 |
are sr5 rotors the same as gt-s? | Rickybobby | 3 | 5,563 |
07-28-2013 11:54 PM Last Post: jondee86 |
