Diffrent Between OEM, TRD & Swift Rear Spring
06-10-2006, 11:41 PM
Please check them out:
This is the over look of the the rear spring, Start form the left - OEM, TRD 6kg/mm, Swift 6kg/mm This is the free length of the OEM - 37cm This is the free length of the TRD 6kg/mm - 22.5cm This is the free length of the BtuneXSwift 6kg/mm - 21.7cm Please Keep in mind that the TRD and Swift are for short stroke shock such as TRD Racing Shock, Tokiko HTS etc. That is the reason why they are at least 15cm shorter then OEM. I will post the spring thinkness of the above springs too, stay tune. Maxwell Arancon Vice President PASS RACING INC 148 S.8th Ave, Unit-F City of Industry, USA [email protected] http://www.passracing.com |
06-12-2006, 11:32 AM
Can you do the same post about front springs?
Thx. Fun is not the straight line! |
06-13-2006, 06:43 PM
I don't have the OEM and TRD Race front spring. I am only have the Swift one. I will post the pic later.
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 6,763 |
SOME 4AG valve spring specs | oldeskewltoy | 5 | 13,337 |
05-04-2015 01:17 PM Last Post: Project D |
Decently heavy vibration in fourth gear between 2000-2300rpm | dinkers542 | 4 | 5,523 |
11-29-2014 12:27 AM Last Post: dinkers542 |
clutch pedal return spring | Eifelaner | 2 | 7,179 |
09-06-2013 10:21 AM Last Post: Apsogos |
Change the meter between zenki and kouki | T_AE86 | 9 | 10,348 |
12-03-2012 03:13 PM Last Post: T_AE86 |
