Diffrent Between OEM, TRD & Swift Rear Spring
06-10-2006, 11:41 PM
Please check them out:
[Image: AEU86 AE86 - Diffrent Between OEM, TRD &...ear Spring]
This is the over look of the the rear spring, Start form the left - OEM, TRD 6kg/mm, Swift 6kg/mm
[Image: AEU86 AE86 - Diffrent Between OEM, TRD &...ear Spring][Image: AEU86 AE86 - Diffrent Between OEM, TRD &...ear Spring]
This is the free length of the OEM - 37cm
This is the free length of the TRD 6kg/mm - 22.5cm
This is the free length of the BtuneXSwift 6kg/mm - 21.7cm
Please Keep in mind that the TRD and Swift are for short stroke shock such as TRD Racing Shock, Tokiko HTS etc. That is the reason why they are at least 15cm shorter then OEM. I will post the spring thinkness of the above springs too, stay tune.
Maxwell Arancon
Vice President
PASS RACING INC
148 S.8th Ave, Unit-F
City of Industry, USA
max@passracing.com
http://www.passracing.com
06-12-2006, 11:32 AM
Can you do the same post about front springs?
Thx.
Fun is not the straight line!
06-13-2006, 06:43 PM
I don't have the OEM and TRD Race front spring. I am only have the Swift one. I will post the pic later.
Maxwell Arancon
Vice President
PASS RACING INC
max@passracing.com
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 7,328 07-31-2019 11:28 AM
  SOME 4AG valve spring specs oldeskewltoy 5 13,833 05-04-2015 01:17 PM
Last Post: Project D
  Decently heavy vibration in fourth gear between 2000-2300rpm dinkers542 4 5,840 11-29-2014 12:27 AM
Last Post: dinkers542
  clutch pedal return spring Eifelaner 2 7,488 09-06-2013 10:21 AM
Last Post: Apsogos
  Change the meter between zenki and kouki T_AE86 9 10,946 12-03-2012 03:13 PM
Last Post: T_AE86
