Digital Dash
05-03-2024, 06:44 PM
(This post was last modified: 05-03-2024 11:59 PM by banpei.)
Post: #191
Digital Dash
I've tried the Spiyda fuel gauge and I wouldn't recommend it. It probably works perfectly fine for correcting resistance-based gauges on resistive-based senders, but I found the output of the 0-5V is unreliable for the ae86 digital gauge cluster. I've contacted the creator and he mentioned it was only supposed to be used for calibration purposes, not for reliable output to gauges. So that was an evening fiddling wasted... Does anyone want to buy a cheap Spiyda fuel gauge?
![]() I did create a voltage divider and that does give me a reliable voltage output between 0.3 and 4.7 volts. I tried to hook it up to the gauge cluster using alligator clips and applied 12 volts to pins 1 and 2, but the fuel gauge kept flashing. I guess this means it doesn't receive a signal as it also does that when it powers up. I'm not sure if it's a broken connection inside my gauge cluster or if I missed something. I'm awaiting delivery of the correct 18-pin connector to create a proper test wiring harness. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,972 |
Dash Waning Lights | pack | 7 | 5,418 |
10-06-2021 01:00 PM Last Post: pack |
Trueno Digital dash kph to mph | Bojack | 3 | 7,819 |
11-21-2018 12:27 AM Last Post: kazi |
Custom Dash Cluster | kazi | 14 | 22,956 |
10-24-2017 09:05 PM Last Post: kazi |
Dash Lights | kazi | 3 | 6,317 |
09-12-2017 10:04 PM Last Post: kazi |
