Disassemble rear axle
10-15-2004, 09:10 AM
Hey Guys,
I'm taking my spare axle appart so here are some pictures ![]() This is after I took the brakes off: ![]() Unscrewing the bolts that hold the brake guards on and hold the half-axle in place: ![]() Adding a tire so we can more easily apply some force to get the axle out: ![]() Axle is out: ![]() And thats where I am at now: ![]() So I got a couple of questions. First off, I can't get the other axle to come off, it's slightly out but the last bit just wont budge. Any tips here? Next up I want to take the brake guards off the half axle so I can clean them up. Do I just slide off the bearing? Or do I need to do something else? Also what should I replace before putting it all back together again? I'm gonne remove the LSD once I get the other half-axle out so keep that in mind aswell
10-15-2004, 11:41 AM
What method did you use on the first axle? Did you hammer that wheel?
I'll look up the picture of the axle assembly for you, so you can figure out how to dismantle the brakeguards of the halfaxles. Getting the bearings off is tough. I think most people split them using an angle grinder very carefully. I'll look up what my manuals have to say about it. FABRICA MI DIEM, PVNC! |
10-15-2004, 11:47 AM
Ivan141 Wrote:What method did you use on the first axle? Did you hammer that wheel?Used a rubber hammer to tap it loose yes, just tap it at different places on the wheel. Why is that wrong? Ivan141 Wrote:I'll look up the picture of the axle assembly for you, so you can figure out how to dismantle the brakeguards of the halfaxles.Hmmm I don't like that idea much. I'm probably better off cleaning the brake guard without taking it off. Need to figure out a good way to do that without damaging the bearing. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-15-2004, 12:52 PM
Hammering in different places should be perfectly okay...The official method is using a slide hammer...maybe you should use some more force, though I can understand that you wouldnt want to break anything.
Before deciding to keep those bearings on there I would first assure myself that they are in good condition. No need to replace 100 euro parts if they are in good shape. FABRICA MI DIEM, PVNC! |
10-15-2004, 12:59 PM
Hi Ivan,
Well I was hammering pretty hard at some point but still, rubber hammer on tire damps the force alot. I just read the post Will did in one of your threads awhile back and suddenly realized I didn't put the old brake disks on, if I put them on without the wheel I should be able to apply a little more force. As for the bearing, I am pretty sure they are still in good shape. So far nothing has indicated this axle isn't any good. If you ask me it came off the car fairly early in its life and has just been lying outside for a long time. Everything just looks to clean and undamaged. But still, I wont know for sure until I drive this axle ![]() I'm just going to find a way to clean the brake covers without taking the bearings out and use some cardboard or somethign to protect the bearings. Just need to be carefull
10-15-2004, 01:02 PM
How weird..I believe that plate is supposed to stay on the axle after removing the halfshafts. I cant remember ever seeing a half shaft with that plate still in place, so it should come off without removing the bearings.
10-15-2004, 01:05 PM
Ivan,
hmmm I need to give it another try then, maybe when I move it right it will slide over the bearing. If so, I'm all set My POR15 should be in next week for painting the axle, and I'll drive over to Ed's to get the calipers and brake covers sandblasted![]() Anyone know a good address for buying a rear caliper rebuild kit? btw, is it smart to replace those gaskets or can I just reuse the ones that are on now? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-15-2004, 02:48 PM
Replace everything./..gaskets arent very expensive (well..maybe when you look at what your getting for your money they are, but overall not a lot). Buy a rebuild kit from toyota. They cost around 30 euros, and you get every little bit you need for a proper rebuild. Keep in minde that it takes some special tools officialy, so it's a lot of work to get everything out and assemble it again.
10-15-2004, 02:52 PM
Hi Ivan,
Ah okay, time to go past the local toyota dealer then.... I would only rebuild the piston, so take it out, replace the seals and put it back in. I'm not going to do the handbrake, Hope they are still good. I've heard those are a nightmare and will always leak when you do them, atleast they do on the RX7 and these calipers look almost identical. I've rebuild my front calipers for the RX7 but still have to try them out. Beside I have the calipers from this axle that I will rebuild and I have working calipers still on my car. If the rebuild fails I will just use the calipers I have now as I know they are good
10-15-2004, 03:14 PM
Euhm i hamered the tire while spinning it and i hammerd with a forhammer :-)
| AE86 rear axle weight | megabob | 11 | 25,974 |
| Axle width | totta Crolla | 1 | 3,476 |
| Door lock disassemble | RWD | 3 | 4,467 |
03-17-2022 02:03 AM Last Post: Bean |
| Rear axle options | Dino86 | 13 | 20,514 |
| Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 5,391 |
![AEU86 AE86 - Disassemble rear axle [Image: AEU86 AE86 - Disassemble rear axle]](http://mux.speed.planet.nl/Pictures/rescale.php?Album=AE86&Image=20041014%20After%20removing%20brakes.jpg&SizeX=640)
![AEU86 AE86 - Disassemble rear axle [Image: AEU86 AE86 - Disassemble rear axle]](http://mux.speed.planet.nl/Pictures/rescale.php?Album=AE86&Image=20041014%20Unscrew%20bolts%20on%20axle.jpg&SizeX=640)
![AEU86 AE86 - Disassemble rear axle [Image: AEU86 AE86 - Disassemble rear axle]](http://mux.speed.planet.nl/Pictures/rescale.php?Album=AE86&Image=20041014%20Add%20tire.jpg&SizeX=640)
![AEU86 AE86 - Disassemble rear axle [Image: AEU86 AE86 - Disassemble rear axle]](http://mux.speed.planet.nl/Pictures/rescale.php?Album=AE86&Image=20041014%20Removed%20half-axle.jpg&SizeX=640)
![AEU86 AE86 - Disassemble rear axle [Image: AEU86 AE86 - Disassemble rear axle]](http://mux.speed.planet.nl/Pictures/rescale.php?Album=AE86&Image=20041014%20End%20result.jpg&SizeX=640)
