Disassemble rear axle
11-09-2004, 05:52 PM
Post: #31
Mux, i have the Toyota parts catalogue, email me your VIN and i'll look up the part numbers for you.
Jon
11-09-2004, 05:54 PM
Post: #32
I posted the links for the EPC toyota catalogue a long while back. Havent you installed it yet mux?
11-09-2004, 06:04 PM
Post: #33
@ivan, hehe well this was probably just a sales guy or something, usually when you talk to one of the mechanics they help out alot. Or maybe the toyota dealer where I checked just sucks.
I haven't installed that catagolue, will do.
@Jon, need to get that vin number tonight, will also post it in the earliest car pageSmile
11-22-2004, 09:52 PM
Post: #34
Alright guys, I finally had time to cut that remaining bolt into pieces...
The whole axle is primed and ready to be paintedSmile
Next step is putting it back together again. Pictures coming soonSmile
11-23-2004, 10:46 AM
Post: #35
Mux his hachi will soon rise above one with air :-) (ssx tricky)
No honestly its going well there in Lisse in the Netherlands he is working hard to get his hachi perfect.
11-23-2004, 01:59 PM
Post: #36
Rise above one with air...
translation please Lennert?
Anyway, lots of nice progress going on here...
05-23-2005, 03:30 PM
Post: #37
I tried to disassemble rear axle last week with special made tool. I was using a sliding hummer with custom made adapter with two wholes for wheel bolts. As you can see on this few pictures. It works. No BIG hummer needed Thumbs up!
Fun is not the straight line!
05-23-2005, 03:57 PM
Post: #38
max_ae86; I tried the thing with the slide hammer as well. It broke. My axle is insane! Sad
[Image: AEU86 AE86 - Disassemble rear axle]
05-23-2005, 05:17 PM
Post: #39
I used the rear end of an AX - no problems getting te axles out
05-23-2005, 06:27 PM
Post: #40
I would advise to weld on some rings to attach a rope to the weight on the slide hammer. Pulling that metal cilinder really fucks up your hands in the long run. The rope also makes it easier to whip the weight faster.
I got the axles out of my axle by beating on the hubs using a large hammer and solid piece of wood to cushion the blows. Took me about 30 minutes of hammering to get one axle out..damn garage put in liquid gasket or loctite between the bearing and axle surfaces.
  AE86 rear axle weight megabob 11 19,199 03-29-2024 11:18 AM
Last Post: FanIsHere
  Axle width totta Crolla 1 1,178 10-24-2023 12:20 PM
  Door lock disassemble RWD 3 2,198 03-17-2022 02:03 AM
  Rear axle options Dino86 13 13,164 01-08-2018 10:19 PM
Last Post: ditn
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,840 12-21-2016 09:37 PM
Last Post: bozu
