Doc's KE20: - really coming together now
06-10-2007, 01:15 AM
Post: #261
Today i finally started on the block Smile
Bought myself an enginestand, so there where no excuses NOT to start on it Big Grin
Crank, pistons and camshaft in:
[Image: AEU86 AE86 - Doc's KE20: - really coming together now]
I eventually went for the TwinRow timing chain, because i heard they are more reliable then the SingleRow one.
Better a bit more weight then a breaking chain i think Big Grin
Final of today:
I've put new rings on the pistons and new big end bearings so it won't break down soon (i hope Big Grin).
Of course all the gaskets and seals are replaced with new ones too.
Hopefully tomorrow i can go on with it Smile
06-10-2007, 01:53 AM
Post: #262
n1 going get a new water pump as well if you ask me
06-10-2007, 02:14 AM
Post: #263
yeah, that's on the list too, but for now i bolted this one on it, so i don't lose the bolts Big Grin
06-10-2007, 12:18 PM
Post: #264
Nice going! Thumbs up!
BTW: How did the MOT go on your other rolla?
06-10-2007, 08:15 PM
Post: #265
i never went to it, i'm gonna take it apart and scrap it Smile
07-26-2007, 11:07 PM
Post: #266
Today i finally finished the engine (well, almost finished Tongue)
Need to get some things and the DCOE intake manifold needs some fiddling, because it hits the exhaustmanifold, sadly Sad
the pics:
Head fitted:
Rockers, push rods fitted and valve's adjusted:
Ignition, oilfilter bracket etc. etc. fitted:
Endresult of today!
07-27-2007, 10:16 AM
Post: #267
Very nice car!! Thumbs up!
A frind of mine is working on a K4 engine so I'm curious what size venturi you use in the carburators and that cam do you use?
07-27-2007, 10:32 AM
Post: #268
Whow, loads of progress!!!
Why didn't you paint some of the engine parts now that it was all appart anyways? You'll have a fully rebuild engine now that still looks like its been in the car for ages...
07-27-2007, 10:59 AM
Post: #269
KrizKH Wrote:Very nice car!! Thumbs up!
Dunno what cam it is, it's a custom cam, and sadly, i don't have any cam specs.
The carbs aren't tuned yet, but i'll let you know when it's done.
Mux213 Wrote:Why didn't you paint some of the engine parts now that it was all appart anyways? You'll have a fully rebuild engine now that still looks like its been in the car for ages...
well... i cleaned them! Big Grin
07-30-2007, 01:40 AM
Post: #270
The clutch was worn (a bit Tongue)
So i swapped it over saturday, and i have the flywheel and stuff lying from my 4K project, so i thought it would be rude NOT to bolt that flywheel to my original engine Big Grin
The original flywheel weighs about 10kgs, the lighter one around 4kgs, so that's quite a bit of difference Big Grin
Everything is fine, i don't feel any negative side effects of it (even idle is not that bad), but i revs quite nice now Hurray!
And i also worked on the suspension, because something was rattling (i thought the pads in the calliper were loose, because i didn't use all the retainers).
Seemed to be a number of problems, so i had to take the shocks from the car, and then it was easy to install my cusco camberplates i had on the shelf for some time Big Grin
The adjusting was wrong, so i just put them on max negative for now, i'm going to get alignment job done on monday Smile
  Another AE86, Duracell. Now with VEMS, and cage... Uzelac 62 88,861 06-22-2015 02:56 PM
Last Post: Uzelac
  My little (not really...) project - Soon to be all done?!? Jan Pedersen 516 588,633 06-27-2013 12:28 PM
Last Post: T_AE86
  AE86 from Portugal (restoring gearbox now...) Homem Bomba 13 23,050 01-01-2013 11:45 PM
Last Post: Homem Bomba
  Levin Coupe from Croatia - NOW SR86 with IRS ZaX 698 731,385 10-01-2012 08:07 PM
  Ricks project AE85 (Back together with dyno results) Rick 132 227,841 07-05-2011 11:54 AM
Last Post: Rick
User(s) browsing this thread: 13 Guest(s)
