Doc's KE20: - really coming together now
06-10-2007, 01:15 AM
Post: #261
Today i finally started on the block
Bought myself an enginestand, so there where no excuses NOT to start on it Crank, pistons and camshaft in: I eventually went for the TwinRow timing chain, because i heard they are more reliable then the SingleRow one. Better a bit more weight then a breaking chain i think Final of today: I've put new rings on the pistons and new big end bearings so it won't break down soon (i hope ). Of course all the gaskets and seals are replaced with new ones too. Hopefully tomorrow i can go on with it "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
06-10-2007, 01:53 AM
Post: #262
n1 going get a new water pump as well if you ask me
06-10-2007, 02:14 AM
Post: #263
yeah, that's on the list too, but for now i bolted this one on it, so i don't lose the bolts
06-10-2007, 12:18 PM
Post: #264
Nice going!
BTW: How did the MOT go on your other rolla? 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
06-10-2007, 08:15 PM
Post: #265
i never went to it, i'm gonna take it apart and scrap it
07-26-2007, 11:07 PM
Post: #266
Today i finally finished the engine (well, almost finished )
Need to get some things and the DCOE intake manifold needs some fiddling, because it hits the exhaustmanifold, sadly the pics: Head fitted: Rockers, push rods fitted and valve's adjusted: Ignition, oilfilter bracket etc. etc. fitted: Endresult of today! "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
07-27-2007, 10:16 AM
Post: #267
Very nice car!!
A frind of mine is working on a K4 engine so I'm curious what size venturi you use in the carburators and that cam do you use? |
07-27-2007, 10:32 AM
Post: #268
Whow, loads of progress!!!
Why didn't you paint some of the engine parts now that it was all appart anyways? You'll have a fully rebuild engine now that still looks like its been in the car for ages... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
07-27-2007, 10:59 AM
Post: #269
KrizKH Wrote:Very nice car!! Dunno what cam it is, it's a custom cam, and sadly, i don't have any cam specs. The carbs aren't tuned yet, but i'll let you know when it's done. Mux213 Wrote:Why didn't you paint some of the engine parts now that it was all appart anyways? You'll have a fully rebuild engine now that still looks like its been in the car for ages... well... i cleaned them! "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
07-30-2007, 01:40 AM
Post: #270
The clutch was worn (a bit )
So i swapped it over saturday, and i have the flywheel and stuff lying from my 4K project, so i thought it would be rude NOT to bolt that flywheel to my original engine The original flywheel weighs about 10kgs, the lighter one around 4kgs, so that's quite a bit of difference Everything is fine, i don't feel any negative side effects of it (even idle is not that bad), but i revs quite nice now And i also worked on the suspension, because something was rattling (i thought the pads in the calliper were loose, because i didn't use all the retainers). Seemed to be a number of problems, so i had to take the shocks from the car, and then it was easy to install my cusco camberplates i had on the shelf for some time The adjusting was wrong, so i just put them on max negative for now, i'm going to get alignment job done on monday "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
Another AE86, Duracell. Now with VEMS, and cage... | Uzelac | 62 | 88,627 |
06-22-2015 02:56 PM Last Post: Uzelac |
My little (not really...) project - Soon to be all done?!? | Jan Pedersen | 516 | 585,329 |
AE86 from Portugal (restoring gearbox now...) | Homem Bomba | 13 | 22,881 |
01-01-2013 11:45 PM Last Post: Homem Bomba |
Levin Coupe from Croatia - NOW SR86 with IRS | ZaX | 698 | 719,579 |
10-01-2012 08:07 PM Last Post: ZaX |
Ricks project AE85 (Back together with dyno results) | Rick | 132 | 226,861 |
07-05-2011 11:54 AM Last Post: Rick |
User(s) browsing this thread: 27 Guest(s)
