Does 4x100 wheels go on hachi
05-14-2006, 09:47 PM
I am little bit confused...does 4x100 go on hachi or not?
[Image: AEU86 AE86 - Does 4x100  wheels go on hachi]
05-14-2006, 10:03 PM
No, you will will need an adapter to make it fit... An AE86 has a 4x114,3 pattern.
05-15-2006, 01:37 PM
Jan Pedersen Wrote:No, you will will need an adapter to make it fit... An AE86 has a 4x114,3 pattern.
In fact there is another workaround - redrilling the stock wheel hubs. I must check is it easy to do Huh Banging head Big Grin
05-15-2006, 02:34 PM
Do you think it's a good idea? You have to drill the brake rotors, the halfshafts (rear). They will be weakened because of this...
05-15-2006, 02:39 PM
SutteR Wrote:Do you think it's a good idea? You have to drill the brake rotors, the halfshafts (rear). They will be weakened because of this...
I'm sure that they will be at least stronger than wheel adapters. There is no reason for any kind of weakening.
  Anyone know what this plug does? Super86 3 7,650 08-01-2016 03:57 PM
Last Post: Nakilad
  How does the 4age AFM system work? heshan 22 29,149 12-20-2012 05:01 AM
Last Post: heshan
  4x100 conversion Eifelaner 22 24,550 12-08-2012 01:14 AM
Last Post: Eifelaner
  MSD 8980 setup - which wire does the dizzy connect to? megabob 8 19,073 11-22-2011 07:02 PM
Last Post: Project D
  Does anyone know where to buy a short steering hub/boss? krullibull 6 8,083 10-12-2011 10:26 PM
Last Post: krullibull
