?? Does AEU86 know about GReddy S-Type ??
01-31-2007, 02:03 AM
This is a new suspension system that was developed by Trust/GReddy for the AE86!
I did a search and found no mention of this... if I'm repeating someone else, all due apologies....
The TWO unique things about this full coilover set up.... 1) you get complete units, including BRAND new spindles! The rear kit utilizes all the original and proper mounting points with both adjustable rear shocks and spring perches.
[Image: AEU86 AE86 - ?? Does AEU86 know about GReddy S-Type ??]
http://www.trust-power.com/06sus_spring/...umper.html
The TWO unique things about this full coilover set up.... 1) you get complete units, including BRAND new spindles! The rear kit utilizes all the original and proper mounting points with both adjustable rear shocks and adjustable spring perches
EDIT: current spring rates are 8kg/mm frt and 6kg/mm rear. Front uses Eibach springs... so you can swap those out easily enough... problem is the rear springs I believe are unique... not leaving much if you don't like a rear 6.0 spring rate
Dan -
01-31-2007, 02:15 AM
so, for like 1300 euro (w/o shipping) you've got a complete suspension set-up. Hmm sounds interesting Smile
01-31-2007, 02:21 AM
The Doctor Wrote:so, for like 1300 euro (w/o shipping) you've got a complete suspension set-up. Hmm sounds interesting Smile
Japan MSRP is ¥188,000
closer to €1200.... if you shop around, you might be able to save another €100....
Dan -
01-31-2007, 03:11 AM
I haven't looked to much at them since they've been here at my house, but I think it will be possible to replace the rear spring with another one. With the way it's set-up it looks as if you can use any spring that's meant for the rear of an AE86. I'm sure it would kill the adjustability of the set-up though, pretty much killing the purpose of a complete kit like this.
Peter Diaz
http://www.shiftgearclothing.com
http://www.ectoyotas.com/forum/
http://www.facebook.com/elfatherae86
01-31-2007, 04:59 AM
Peter I dont think it would hurt the adjustability of the rear spring setup at all, if you look at it logically all you're doing is raising or lowering the point to which it makes contact. it shouldn't effect the adjustability at all...
01-31-2007, 05:04 AM
Plex Wrote:Peter I don't think it would hurt the adjustability of the rear spring setup at all, if you look at it logically all you're doing is raising or lowering the point to which it makes contact. it shouldn't effect the adjustability at all...
That's a good point. The only reason I think it would change it is the length of a new spring compared to the length of the spring used in the original set-up. I would think the ride height adjustability of the car would change.
Peter Diaz
01-31-2007, 06:56 AM
Check out http://www.greddy.com/news/?id=16 they have it there, with price and all
My evil Red/Black Panda
My current JDM AE86 project
01-31-2007, 05:58 PM
BTW, I did mention these a while ago..you must have missed it.
01-31-2007, 06:26 PM
Yeah we talked about it but that was awhile back and when it wasn't for sale yet wasn't it Ivan? i tried searching for the thread before when answering the K and D2 suspension thread but couldn't find it to easily aswell. But it exists, somewhere in the distant pastBig Grin
Defo a really nice set seeing all bits are included.
02-01-2007, 12:57 AM
Peter Diaz
  Help me AEU86, you're my only hope Nakilad 38 17,368 04-10-2021 05:19 PM
Last Post: Nakilad
  Exhaust has white smoke coming out and I dont know why... mister86 3 4,862 01-19-2020 12:06 AM
Last Post: Power_uP
  Anyone know what this plug does? Super86 3 6,531 08-01-2016 03:57 PM
Last Post: Nakilad
  ford type 9 gearbox with 4age engine filh 29 50,351 01-11-2015 01:02 PM
Last Post: filh
  Anyone know how to fix the digital clock? kawo 0 3,486 05-02-2014 08:54 AM
Last Post: kawo
