MAP/AMF???
07-27-2006, 11:31 AM
MAP/AMF???
NoHachi Wrote:Not true. ITB's+ hot cams are the one situation where an AFM based setup would be infinately more easy to setup and tune. I think most of the hot cammed ITB engines run TPS based load sensing, not MAP based. As its very difficult to generate consistent and decent vacuum with the short trumpets. Either way, AFM would result in better fueling at the cost of slightly less power.but then, as said, you would need an intake manifold.. to fit the AFM too... so not too easy as well ![]() AE86 ex-daily |
AFM to Map Conversion | ps13michi | 3 | 3,620 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 11,890 |
extracted freedom ecu 16v ignition map | ditn | 7 | 9,341 |
smallport question AFM or MAP? | fax0815 | 5 | 8,633 |
05-17-2014 05:07 AM Last Post: jondee86 |
Tutorial : Megasquirting an European (MAP) AE86 (4age) | gon | 68 | 186,691 |
01-09-2014 11:23 PM Last Post: Bean |
