ECU - MAP or AFM version?
02-03-2005, 12:13 PM
Can anyone tell me, if this ECU is a AFM or a MAP version? Or is it the same ECU for both versions?
02-03-2005, 12:22 PM
Looked it up on the EPC and it was Euro spec ecu from late spec AE86, so that would make it MAP i guess
[Image: AEU86 AE86 - ECU - MAP or AFM version?]
02-03-2005, 12:34 PM
Thanks JonT! Would you please check this one too?
Confused
Your ECU is for ae86 from 8505 to 8704, EUG (europe general).
As my ae86 is afm and has 89661-12100 ecu (8502-8608, SDZ - swiss and sweden), I think your is MAP...
02-03-2005, 12:38 PM
My epc gives 2 results for the 2nd one :
1. 8308-8505 AE86 GT EUG (europe general)
2. 8402-8505 AE86 RHD (right hand drive) GEN (general countries) SINGAPURE package
02-03-2005, 01:32 PM
I agree, screen print from epc attached
Dreja, did you muddle the numbers on your first post ? only you said yours had the 12130 and was AFM ?
Out of interest, i talked to Fensport a while back about ECU's, and they had tested all the different ones in a standard car and found no difference between them.
02-03-2005, 01:40 PM
Sorry, I've made a mistake (I have corrected the post now). I have 89661-12100 and is AFM.
btw jon you have a pm Smile
Andrej
02-03-2005, 01:44 PM
89661-12220 is also AFM by the way..just to make the list a bit more complete.
02-03-2005, 02:02 PM
2 all:
Is there a way to determine which ECU is MAP version ?
02-03-2005, 02:07 PM
Ivan, the 89661-12220 is from ae92...
  AFM to Map Conversion ps13michi 3 3,116 01-06-2022 10:34 AM
Last Post: ps13michi
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 10,964 02-10-2020 06:39 PM
Last Post: Power_uP
  extracted freedom ecu 16v ignition map ditn 7 8,817 08-22-2016 10:01 AM
Last Post: ditn
  Bluetop AFM with air filter izanagi 4 6,975 04-29-2016 07:29 PM
  smallport question AFM or MAP? fax0815 5 8,253 05-17-2014 05:07 AM
Last Post: jondee86
