EDM GT-S Cluster, PWR light VSV?
06-25-2017, 02:19 PM
Another day, another gripe! Smile
I want this PWR light (Novelty item, I know) working (Since I have it, and it`s cool):
I know which wire it is, #2 Green-Red:
I traced it to the engine bay K plug:
And according to the wiring diagram it should be like so:
Problem is though, I looked at the placement of all stuff in engine bay:
And I`ve found VSV for T-VIS, 12v power supply Black-Red wire on 14P (G) plug on Junction Box No.4, Ground via #9 pin on ECU 18P (at around 4500rpm).
I`ve found idle VSV that is controlled by Idle-Up Computer.
And I`ve found the secondary A/C idle VSV.
But I cannot find any earthed VSV (K plug) for the PWR lamp...
Any takers? Smile
1x TA60 82' Sedan 2T 8V
06-25-2017, 08:00 PM (This post was last modified: 06-25-2017 09:57 PM by Rascal21.)
Ah, finally I was able to access a proper EPC and found the elusive Vacuum switch!
Now to get one Smile
Case closed!
Edit: Picture of how it looks like and parts number, for future reference to others:
Parts name and number:
SWITCH ASSY, VACUUM(FOR ECONOMETER)
83391-16020
  EUDM gauge cluster banpei 22 5,544 08-15-2023 10:48 PM
  ECON and PWR light troubleshooting magpie 3 1,889 07-18-2023 01:28 PM
  EUDM cluster revelations banpei 1 1,411 06-23-2023 09:11 AM
Last Post: r.ave
  PWR light issue and no brake fluid after winter storage magpie 10 3,156 05-25-2023 08:09 AM
  Custom Dash Cluster kazi 14 21,053 10-24-2017 09:05 PM
Last Post: kazi
