EU zenki turn signal problem/question
05-04-2007, 12:24 PM
Hey people,
another day another problem Logicaly, there must be a wiring problem. I checked the cables and they seem to be ok (as I said it worked great 3 weeks ago), so I have no idea where to start. One thing though concerns me, I tried to unmount the front left quaterpanel turnsignals (they didnt work since I got the car) to check if the problem is with the bulb but I didnt manage to get it, it sortof "fell" inside the quaterpanel, though the wiring stayed intact. I would like to ask if the front and side turn signals work in one closed electrical cicle, which would mean that damaging the side signals will cause the front ones not to work. This will give me an idea where to start I tried to remove the quaterpanel to check but had no luck at all, the thing seems to be glued or something...Thanks a lot people ![]() EDIT: Thanks boys for the Tech FAQ page, I managed to find the electrical wiring diagrams But I dont understand sh*t anyway.... Heres the wiring of turn signals, as far as I understand it seems that the front turn signals should work even when the side signals wont... In that case, where could the problem be?
86ers.org AE86 x GXE10 |
| Start wont turn over after installing radio | MC_JP | 6 | 13,891 |
09-22-2014 11:13 PM Last Post: izanagi |
| Toyota COPs tach signal | Jan Pedersen | 5 | 9,638 |
01-14-2014 02:49 PM Last Post: Jan Pedersen |
| 4agZe problem solved - 99% IC problem | Okami | 41 | 52,372 |
07-12-2012 04:49 PM Last Post: Okami |
| Zenki trueno indicatop and zenki levin bumper MR2 aw11 | BOOMEX | 3 | 8,456 |
12-28-2011 12:16 PM Last Post: BOOMEX |
| VSS signal from stock cluster ? | Uzelac | 7 | 12,923 |
12-13-2011 01:42 PM Last Post: Uzelac |
I tried to remove the quaterpanel to check but had no luck at all, the thing seems to be glued or something...![AEU86 AE86 - EU zenki turn signal problem/question [Image: AEU86 AE86 - EU zenki turn signal problem/question]](http://img152.imageshack.us/img152/8788/wiringii7.th.jpg)
