Toyota COPs tach signal
01-13-2014, 09:14 PM
The 1ZZFE coils I am using have a tach output but what kind of signal do they put out? I tried using a oscilloscope connected to ground but I got no signal. I did not try with the scope connected to 12 V or by using a pull up resistor and this will be next if I can't find a certain answer.
Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
01-14-2014, 10:07 AM
It's not a tach output but a feedback (confirmation) signal.
Far as I know, it's a 5V square wave signal, like in most Toyota. |
01-14-2014, 10:39 AM
You are right it is a feed back to the ECU but I would like to use it as a tach signal
![]() Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
01-14-2014, 10:51 AM
I knew we where talking about that few years ago.
Look here: http://www.aeu86.org/viewtopic/ae86/t/10...c/start=25 |
01-14-2014, 02:49 PM
Nice! Did you ever get the S2k dash working?
VSS signal from stock cluster ? | Uzelac | 7 | 10,241 |
12-13-2011 01:42 PM Last Post: Uzelac |
left turn signal always flashes. bulbs are good | Mitchen | 1 | 3,275 |
07-27-2010 12:33 AM Last Post: Mitchen |
Tacho Signal Levin Coupe with pics | Okami | 10 | 14,965 |
05-31-2010 08:56 PM Last Post: Ivan141 |
tacho signal wire | totta Crolla | 7 | 13,612 |
04-12-2010 09:44 PM Last Post: Okami |
EU zenki turn signal problem/question | Spitfire | 1 | 3,563 |
05-04-2007 12:24 PM Last Post: Spitfire |
