Engine Check Light at High RPM
10-13-2014, 04:49 AM
When I accelerate through to high RPM (6000+) the engine check light comes on for about 10 seconds and then goes off. Any ideas as to what this could be?
Engine is Bigport, air filter, extractors, exhaust. Otherwise stock.
Cheers
Simon
http://www.super86.co.nz
10-13-2014, 10:14 AM
Do you have an oil pressure gauge?
Could be oil cavitation at high revs, dropping your pressure :/
10-13-2014, 04:13 PM
AE86 dont have a oil pressure light! Check for fault codes. Does it loose any power/ missfires/ any other symtoms?
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
10-13-2014, 08:26 PM
had this kind problem with an old engine. It was saturated injectors.
10-30-2014, 03:01 AM
Nope, no other symptoms. I haven't had a chance to check for codes, but have done a track day since it started. Only a problem at approx 6500rpm and seems to be lower in rpm as the car gets hotter. It effectively is like a lowered rev limiter.
Engine has good oil pressure, and is not getting hot.
10-30-2014, 09:33 AM
You've grabbed a chance to do a track day but not to check codes? If a 5 min job is too much trouble but a trackday is not I'd say you've got your priorities backwards.
10-30-2014, 02:19 PM
Exacatly , why whould you go on a trackday if your car aint right, it doenst even take 5 minutes! Thats like going on a marathon on crutches...
10-30-2014, 06:05 PM
More like marathon with heart problem Tongue
11-03-2014, 11:03 AM
Thanks for your concern about my cars welfare guys! I actually had thought that i'd fixed it with changing plugs and leads as well as cleaning out all of the intake and electrical connections on the distributor, however it was not to be!
I'll check the engine codes and report my findings.
Cheers
  High-beam warning lamp Mylesmck 4 1,483 07-21-2023 07:44 AM
  No idle below 2000 rpm rich running Steller Engineering 3 1,438 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine stress at high speeds gh0st 6 2,464 08-30-2022 07:11 PM
Last Post: Power_uP
  4AGE 16V engine overheat when at high speed chenfon 32 21,335 12-31-2020 06:39 AM
Last Post: chenfon
  Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) Rascal21 41 33,581 08-21-2016 04:51 PM
Last Post: ray
