Engine Light code 4 and code 8
08-17-2009, 09:35 AM
Dear All,
I have the following problem in my small port. Please help! I have the check engine warning light on, after I short the termainal E1, code 4 and code 8 is indicate. Lets deal with Code 8 first, cold air temp. sensor, as I change my air filter to a after market one, since then I dont have it, but it should not appear and should be "no show" for the check engine light unless I short E1 terminal for inspection. So, I guess this one I can ignore it. Code 4, water temperature sensor, I have check the wiring and the Ohm for the temp. sensor, everything seems to be normal. But the check engine warning light still on. So, I have no idea, thank to help me on this one or any other possible reason. Of course, I have reset the ECU by removing -ve terminal on the battery after I did the check. Thank you very much! |
08-18-2009, 09:31 AM
Okay, I fix the problem , thanks!
08-18-2009, 11:34 PM
you did the reset and the check but did you do a "mini trip" to "see" after if they indicate again?
The air temp sensor is http://www.toyodiy.com/parts/p_E_1986_TO...l?hl=89424 **COROLLA EE80 - 4AGE 124HP** ![]() |
08-19-2009, 02:05 AM
Now my engine seems fine and no more warning light lu..
Thanks anyway! ![]() |
ECON and PWR light troubleshooting | magpie | 3 | 1,943 |
07-18-2023 01:28 PM Last Post: banpei |
PWR light issue and no brake fluid after winter storage | magpie | 10 | 3,217 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 7,929 |
Engine Check Light at High RPM | Super86 | 8 | 9,005 |
11-03-2014 11:03 AM Last Post: Super86 |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,404 |
