Engine Light code 4 and code 8
08-17-2009, 09:35 AM
Dear All,
I have the following problem in my small port. Please help!
I have the check engine warning light on, after I short the termainal E1, code 4 and code 8 is indicate.
Lets deal with Code 8 first, cold air temp. sensor, as I change my air filter to a after market one, since then I dont have it, but it should not appear and should be "no show" for the check engine light unless I short E1 terminal for inspection. So, I guess this one I can ignore it.
Code 4, water temperature sensor, I have check the wiring and the Ohm for the temp. sensor, everything seems to be normal. But the check engine warning light still on. So, I have no idea, thank to help me on this one or any other possible reason.
Of course, I have reset the ECU by removing -ve terminal on the battery after I did the check.
Thank you very much!
08-18-2009, 09:31 AM
Okay, I fix the problem , thanks!
08-18-2009, 11:34 PM
you did the reset and the check but did you do a "mini trip" to "see" after if they indicate again?
The air temp sensor is
http://www.toyodiy.com/parts/p_E_1986_TO...l?hl=89424
**COROLLA EE80 - 4AGE 124HP**
[Image: AEU86 AE86 - Engine Light code 4 and code 8]
08-19-2009, 02:05 AM
Now my engine seems fine and no more warning light lu..
Thanks anyway! Thumbs up!
  ECON and PWR light troubleshooting magpie 3 3,184 07-18-2023 01:28 PM
  PWR light issue and no brake fluid after winter storage magpie 10 5,593 05-25-2023 08:09 AM
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 10,114 11-09-2020 10:51 AM
Last Post: totta Crolla
  Engine Check Light at High RPM Super86 8 10,682 11-03-2014 11:03 AM
Last Post: Super86
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 9,731 10-30-2013 11:18 PM
