Engine died.... :(
04-07-2007, 01:56 PM
Engine died.... :(
HI!
I made full service on my 4age with new watherpump, oil etc...
I also installed a mocal oil cooler kit with sandwich plate, i connected the stock oil cooler hoses together, to let the oil run back in the engine.
Oil pressure was okay, but my engine made strange noises coming from the valve train, yesterday i heard a new sound like tok tok tok, and the engine didnt run on idle, i have to start it again and again.
Now the engine is dead, the starter turns but no way to fire on this thing...
04-07-2007, 02:30 PM
Engine died.... :(
I don't know exactly how you have this thing piped up,
but stock 4AGE oil coolers are a bypass type. Excess oil
goes to the cooler when the oil pressure is greater than
the relief valve setting. Oil return is from the cooler direct
into the sump.
If you put a different sandwich plate in there (one that
sends ALL the oil to the cooler) and you plumbed the oil
return from the cooler into the sump return.... then you
would not have any oil going to the engine lube system Huh
This would lead to various tapping, knocking, and ultimately,
crying sounds Sad But on the bright side, your oil temp would
have been 30 or 40 deg lower than before.....
I hope I'm wrong, but if not, you have my sympathy dude...
Cheers... jondee86
04-07-2007, 02:58 PM
Engine died.... :(
My setup looks like this
The red hose is the connection from the stock oil exit and entrance, the green ones are the adaptor plate to the oil cooler.
[Image: AEU86 AE86 - Engine died.... :(]
04-07-2007, 07:20 PM
Engine died.... :(
no one a clue?
04-07-2007, 07:39 PM
Engine died.... :(
Nope, but I dont really see where the "stock oil exit" comes from..
The stock setup has a bypass feed coming out of the sandwich plate under the filter, and an oil return to the oil pan right underneath the filter.
You're new setup has a different sandwich plate I guess, so the routing towards the oil cooler should be OK I think. But what have you connected to the old oil return? The only oil exit there is for the pressure sensor AFAIK.
Anyway, dont go playing with the engine anymore right now... drain the oil and run a magnet through it.. should give you a clue of what damage has been done.
04-07-2007, 07:50 PM
Engine died.... :(
I just connected the stock oil exit with the stock oil inlet togther, you see it on the picture...
04-08-2007, 01:56 AM
Engine died.... :(
Dude, all the oil from the pump is directed towards the stock
oil filter. Once filtered, it goes back into the block and lubes
all the bearings. If you are allowing a full flow of oil from the
original filter location to return directly to the sump, then you
have done a bad thing.
Your pic shows you have made a loop to the stock sump return.
I can't really see how you could do this without using some sort
of remote filter adapter and plugging the return port off Confused A
photo or a more detailed sketch of the hose arrangement at
the stock filter location would help.
But as above, time to start checking bearings....
Cheers... jondee86
04-08-2007, 09:11 AM
Engine died.... :(
http://img78.imageshack.us/img78/3814/pr12us0.jpg
Sandwichplate
04-08-2007, 11:14 AM
Engine died.... :(
I see... you mounted the new sandwich plate on top
of the factory one. So, what you did connecting the
factory oil supply (to cooler) directly to the factory
oil return (to sump) should not be a problem.
Oil only flows in this loop when the engine revs and
oil pressure are high. The rest of the time there is no
flow because the spring-loaded relief valve is closed.
Of course, you have to leave the relief valve in place
to sustain oil pressure in the engine. You didn't take
the valve and spring out did you ??
And the new sandwich plate should not care if the old
one is there or not. The only downside is that adding
the new cooler and pipework will increase the back
pressure on the relief valve, causing it to bypass a
bit more oil than before.
Again, shouldn't be a problem, as there would still
be enough oil pressure/flow to lube the engine. Only
a total blockage somewhere in your cooler pipework
would stop oil flow to the bearings.
Cheers... jondee86
04-08-2007, 11:31 AM
Engine died.... :(
I just closed the stock oil circle, i didn“t take anything out...
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 11,053 10-30-2013 11:18 PM
  Battery died. Headlights now go up but not down. Age86 4 6,689 09-15-2008 01:18 PM
  Need engine,any engine Apolan 25 28,335 10-29-2006 06:55 PM
  Car died on me today, RIP fuelpump? Ivan141 12 15,427 11-21-2005 11:54 AM
