Engine problems! PLEASE help!
08-20-2005, 09:21 PM
Ok, a couple of things first.
STOP DRIVING THE CAR WHILE IT PINGS!!!!!!!!!!!!!!!!
You are probably experiencing detonation..a very harmful situation that will destroy your engine if you keep driving.
Problem B is a well known quirk with AE86. During hard lateral forces, oil comes out through the carter decompression tube (what the hell is that thing called for real?) into the inlet manifold//thus making you produce nice puffy clouds of smoke. Build yourself a catchcan and often check oil level..you'll be ok.
Problem 1 is much more serious though..It might be just a faulty injector causing a lean situation. Take out the suspected injector others...has the pinging also moved, then you have and switch it with one of the found your culprit..If not, then report back and we'll search further.
Might be in Ljublana again in the second week of September, so if you haven't found it by then I could take a look in person.
Messages In This Thread
Engine problems! PLEASE help! - Apolan - 08-20-2005, 08:53 PM
[] - Ivan141 - 08-20-2005 09:21 PM
[] - Ivan141 - 08-20-2005, 09:26 PM
[] - dreja - 08-20-2005, 10:21 PM
[] - robokill - 08-21-2005, 12:33 AM
[] - Apolan - 08-21-2005, 11:08 AM
[] - Apolan - 08-21-2005, 07:30 PM
[] - NoHachi - 08-21-2005, 08:25 PM
[] - Apolan - 08-21-2005, 09:46 PM
[] - NoHachi - 08-21-2005, 09:51 PM
[] - dreja - 08-22-2005, 07:41 AM
[] - Jezza_hr - 08-22-2005, 10:04 AM
[] - NoHachi - 08-22-2005, 11:06 AM
[] - Ivan141 - 08-22-2005, 11:55 AM
[] - apardal - 08-22-2005, 03:14 PM
[] - apardal - 08-22-2005, 03:16 PM
[] - Apolan - 08-23-2005, 02:59 PM
[] - NoHachi - 08-23-2005, 03:21 PM
[] - Apolan - 08-23-2005, 03:26 PM
[] - Apolan - 08-23-2005, 03:41 PM
[] - Miguel - Newera - 08-23-2005, 04:12 PM
[] - dreja - 08-23-2005, 05:51 PM
[] - NoHachi - 08-24-2005, 05:03 AM
[] - Ivan141 - 08-24-2005, 09:08 AM
[] - Apolan - 08-24-2005, 12:13 PM
[] - JonT - 08-24-2005, 12:59 PM
[] - Apolan - 08-25-2005, 03:48 PM
[] - Apolan - 08-25-2005, 03:53 PM
[] - Ivan141 - 08-25-2005, 04:31 PM
[] - Apolan - 08-26-2005, 05:48 PM
[] - NoHachi - 08-26-2005, 05:57 PM
[] - Ivan141 - 08-26-2005, 08:06 PM
[] - Apolan - 08-27-2005, 12:00 AM
[] - Kas - 08-30-2005, 12:31 AM
[] - apardal - 08-30-2005, 03:37 PM
[] - Apolan - 09-06-2005, 11:14 AM
[] - @dodo@ - 09-06-2005, 11:22 AM
[] - Apolan - 09-06-2005, 03:04 PM
  Big wheel problems gh0st 16 8,005 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 2,595 08-31-2021 06:20 PM
Last Post: totta Crolla
  TUV RHD AE86 Germany (help please) 4dori 9 6,810 07-17-2019 07:42 PM
Last Post: Hachigo83
  Problems Mintex M1155 pads Dino86 9 8,790 07-04-2017 11:22 AM
  Carb question please help MIGGZFSU 3 4,617 03-29-2017 03:06 PM
Last Post: MIGGZFSU
