Engine running lean
07-13-2005, 08:29 PM
Engine running lean
However
Knudsen Wrote:Mine is 2200 cold and 1200 hot. But thats cuz i hate if the idle is to low when hot... With a idle beneath 1000 rpm, the 4AGE has a tendensy of hesitating when you startup from standstill. This I understand. I keep feeling like the engine is about to stall at any moment and it can be kind of annoying ![]() |
07-13-2005, 08:51 PM
Engine running lean
My engine was running when hot at 1300 rpm, and I rotete ignition distributor just a little, and now engine is running at 900 rpm. Now, engine is running smoother.
1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
07-14-2005, 08:48 AM
Engine running lean
Most 4age's I know dont run very neatly under 1000 rpm's, but I have witnessed one running at 500rpm, not shaking or hesitating, and not even a breeze from the crankcase ventilation hose. This was in a meticulously maintained ae82 GT. So a GOOD 4A-GE should be able to run like a champ at lower rpm's.
07-14-2005, 09:43 AM
Engine running lean
banpei Wrote:Euh, fixed now: it turned out that the clutch-fluid was almost gone in the pedal. I probably have a leak somewhere.Knudsen Wrote:Mine is 2200 cold and 1200 hot. But thats cuz i hate if the idle is to low when hot... With a idle beneath 1000 rpm, the 4AGE has a tendensy of hesitating when you startup from standstill.Well, it's okay for me: it is not really hesitating, except when in reverse. ![]() Anyway, refilled it and now it doesn't stall in reverse anymore... Weird! ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,741 |
Running issues | sam3007 | 6 | 3,145 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 8,011 |
Anyone running DIY Coilovers? | Rasteirinho | 8 | 14,089 |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 8,415 |
User(s) browsing this thread:
