Engine running lean
07-13-2005, 08:29 PM
Engine running lean
However
Knudsen Wrote:Mine is 2200 cold and 1200 hot. But thats cuz i hate if the idle is to low when hot... With a idle beneath 1000 rpm, the 4AGE has a tendensy of hesitating when you startup from standstill.
This I understand. I keep feeling like the engine is about to stall at any moment and it can be kind of annoying Undecided
07-13-2005, 08:51 PM
Engine running lean
My engine was running when hot at 1300 rpm, and I rotete ignition distributor just a little, and now engine is running at 900 rpm. Now, engine is running smoother.
1984 AE 86 Levin hatchback
1989 AE 92 GTi
2004 Kawasaki KLE 500
07-14-2005, 08:48 AM
Engine running lean
Most 4age's I know dont run very neatly under 1000 rpm's, but I have witnessed one running at 500rpm, not shaking or hesitating, and not even a breeze from the crankcase ventilation hose. This was in a meticulously maintained ae82 GT. So a GOOD 4A-GE should be able to run like a champ at lower rpm's.
07-14-2005, 09:43 AM
Engine running lean
Well, it's okay for me: it is not really hesitating, except when in reverse. Undecided
Euh, fixed now: it turned out that the clutch-fluid was almost gone in the pedal. I probably have a leak somewhere. Undecided
Anyway, refilled it and now it doesn't stall in reverse anymore... Weird! Confused
[Image: AEU86 AE86 - Engine running lean]
  No idle below 2000 rpm rich running Steller Engineering 3 2,795 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Running issues sam3007 6 4,493 06-26-2022 01:34 PM
Last Post: Dave W
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 10,108 11-09-2020 10:51 AM
Last Post: totta Crolla
  Anyone running DIY Coilovers? Rasteirinho 8 15,628 11-19-2013 10:30 PM
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 9,726 10-30-2013 11:18 PM
