Engine wont rev. Fuel pump?
02-16-2007, 08:05 AM
...Or wait for jamie to drop by the topic and mention that you can get the fuel pump off of a 7M supra at any given scrapyard and it will be bolt-on
02-16-2007, 06:10 PM
domi my friend, BadDog use my ex-7MGTE pump already for his 4AGTE project
02-17-2007, 08:07 AM
did you already try replacing the fuel filter? if it's equipped w/ a catalytic converter, could it be clogged and it's time to put in a new one or go test pipe?
![]() "Strictly All Things 86" |
02-17-2007, 08:26 AM
What bugs me is the circumstance - why would either one happen while running low on fuel... Could it gather such a massive ammount of junk in the tank to actually have such a great effect on fueling/exhaust system??
02-17-2007, 12:02 PM
domi Wrote:What bugs me is the circumstance - why would either one happen while running low on fuel... Could it gather such a massive ammount of junk in the tank to actually have such a great effect on fueling/exhaust system??Thats what happened with my DeLorean.... Especially a car that has stood still for any given period of time in its life collects loads of gunk in the fuel tank. Normally the fuel filter should take care of it, but if it gets clogged up you already have a problem, but also if it lets the junk go through it can really mess things up further down the lines clogging injectors and that sorta stuff.. Still I doubt thats the case here. Fuel filter may simply be needing a replace and a faulty fuel pump could still be the case. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
02-19-2007, 03:46 PM
What should be the pressure of stock fuel pump? I'm thinking about to measure the pressure now, and see is it different from stock.
White ae86 Levin |
02-19-2007, 04:39 PM
You must deliver at least 2.3bar at the fuel rail.
Most EFI pumps must deliver 4 bar, then pressure regulator ensure correct pressure for injectors for every particular situation. |
02-19-2007, 06:36 PM
Is this carb or injected???
carb type(diaphram) pumps don't usually die do to insufficient fuel, intank electric fuel pumps can be damaged/destroyed in less then 10 seconds of running on empty! Is the problem the same in gear as well as not in gear? Check the fuel filter... junk can always be swept from the bottom of the tank Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-27-2007, 05:53 PM
Bump!
Few questions more: Where is the fuel pump located? How to remove it? White ae86 Levin |
02-27-2007, 06:19 PM
pump is under the trunk (in the fuel tank) on 4AGE powered cars and attached to the engine on 3 or 4AC powered cars.
drop the tank straps, lower the tank, remove the pump frame.... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
20v BT - which oil pump? | Mylesmck | 4 | 2,923 |
Fuel pump issue | DJexor | 11 | 5,451 |
fuel line hose from the pump | Wikizz | 4 | 6,178 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
Raising the rev limit on stock ECU | fax0815 | 2 | 11,075 |
08-31-2015 02:04 PM Last Post: gon |
4age 16v oem ecu rev limiter research | ditn | 18 | 28,802 |
06-22-2015 08:02 AM Last Post: ditn |
