Crankshaft problem and what i need?
06-06-2008, 05:16 PM
The 20v chrankshaft will fit to 16v model with 40mm diameter of connection rods? i need the pistons but i only found with 20mm pin my is 19
06-06-2008, 05:41 PM
pernati Wrote:The 20v chrankshaft will fit to 16v model with 40mm diameter of connection rods? no... the rod journals for both 20V engines is 42mm pernati Wrote:i need the pistons but i only found with 20mm pin my is 19 You have 19mm wrist pins?? Do you have a photo of the pistons?? Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-13-2008, 11:23 PM
TRD are 19 mm pistons are you sure?
Crankshaft stamping | Blaze0010 | 6 | 1,652 |
06-10-2024 10:16 PM Last Post: Blaze0010 |
Which new bearings for ae101 4AGZE crankshaft&connecting | ditn | 4 | 7,426 |
10-31-2013 06:04 PM Last Post: ditn |
4agZe problem solved - 99% IC problem | Okami | 41 | 37,719 |
Maybe problem with TRD shock absorber and springs | Mattolo | 22 | 21,707 |
10-15-2011 07:40 PM Last Post: zenki |
crankshaft timing belt pulley won't come off | Dino86 | 8 | 9,820 |
02-21-2011 02:05 PM Last Post: Project D |
