Extra electric fan in ae86. How to?
06-12-2008, 04:56 PM
Hello!
I want to install extra electric fan for better cooling radiator. But how to do it? What side to mount it? It should be blowing fresh air TO radiator, or hot air FROM the radiator?
[Image: AEU86 AE86 - Extra electric fan in ae86. How to?]
06-12-2008, 05:41 PM
If you mount it in front of the radiator, then it needs to blow air through the radiator to the engine. Another option is to find yourself a radiator shroud so the mechanical fan can work more efficiently.
06-12-2008, 11:14 PM
With an electric fan, you don't need the engine fan.
Just remove the original and enjoy the power gain!
And this new fan should be installed the same way the stock one is. Between the engine and the radiator, blowing air to the back of the car.
Best regards
06-13-2008, 01:43 AM
Viscous coupling fans reduce throttle response, so it's a good idea to switch to electric.
They don't work well in reverse direction, so use a PULL type fan. There's enough space in there for 2 smaller fans, which work better too. You can also wire a switch from the dashboard to the electric relay(s), so the fan won't only work when the thermo switch comes on (Mine comes on from 90 Deg C), but permanently whilst the switch is on - this is especially useful for drifting, when you'll be spending quite a lot of time sideways where air isn't flowing well through the radiator, naturally.
Also, if you shroud and oil cooler well against the radiator, the fan(s) will help pull air through that too. Thumbs up!
VISIT OUR NEW WEBSITES!!!!
A Tuner's Paradise
Automotive Art On Film
Dedication To Automotive Perfection
Japan Office Tel - (Calls charged at UK National Rate): 0207-193-3979.
Mobile (Japan): +81- (0) 90-4133-3825 Fax (Japan): +81-(0) 47-307-4678
06-13-2008, 02:40 PM
I use a this type Datsun Cherrys fan, and I put it this way. So it is same way that it is in originally in Datsun, and now it blows air through radiator.
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
06-13-2008, 08:03 PM
Hmmm. 2 fans is not necessary, one puller fan is all that is needed for proper cooling. A pusher fan with your stock fan seems like overkill.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
06-13-2008, 08:34 PM
yeah bin the viscous one,it doesnt matter if you fit a push or pull electric,whatever your local scrapyard has really!! i got a fiesta deisel fan as its got the nice curved blades and its quite new,cost less than 10 pounds,fits right in the original fan cowling too
  electric water pump?? Uzelac 8 13,030 04-09-2012 05:20 PM
Last Post: Jimmi The Kid
  Electric Power Steering - What options are available Rasteirinho 15 25,423 02-29-2012 07:10 PM
  Electric steering column, need help please! Jimmi The Kid 12 20,960 02-29-2012 07:04 PM
  Electric Power Steering Pump Jezza_hr 5 11,070 09-02-2011 09:25 AM
Last Post: Lauren
  Electric Fan Rasteirinho 3 5,124 08-17-2011 03:27 AM
Last Post: bozu
