Few issiues with my AE86 (dash and engine)
03-13-2014, 10:35 PM
Hey, I recently run into a few probs with my AE86 and i was hopeing you guys could help me.
1 My engine was stuttering at 3000 rpm once, the check engine light (only happend once) 2: oil level and fuel gauge do not work on my dashboard cluster, i do have a spare one. but not know whats best to do can you please help ? thanks Build your dreams. Ford Puma 1.7 Zetec-s Daily Toyota AE86 Levin Coupe "Jinxy"- Dreamcar Mitsubishi sapporo - bosuzoku project |
03-13-2014, 11:26 PM
Engilne levelwhat ?
Fuel gauge level and reserve light are connected from fuel tunk with two thin yellow wires, and share same ground. First check if there is change in resistance on fuel level when you add/remove fuel and if there is short ciurcit when there is low fuel. After that check continuity from dash to fuel tank connector. Wires are runed from tank to driver side fuse box and from there go to dash. |
03-14-2014, 12:03 AM
Uzelac Wrote:Engilne levelwhat ?Sorry, i edited my post, it was oil level gauge Uzelac Wrote:Fuel gauge level and reserve light are connected from fuel tunk with two thin yellow wires, and share same ground. Thank you, i know there is a red/white cable disconnected that runs to my trunk, but i do not know what it is. Will gonna check my wiring then Build your dreams. Ford Puma 1.7 Zetec-s Daily Toyota AE86 Levin Coupe "Jinxy"- Dreamcar Mitsubishi sapporo - bosuzoku project |
03-14-2014, 12:42 AM
Check if the singe yellow/ black wire is connected to the oilpressure (not level!) sensor. its that big round thing underneath the dizzy.
As for the engine issue, have you checked your diagnostic codes, that should have stored an error, if there was something major. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
03-14-2014, 07:14 PM
Diagnose it, and if oil pressure sender doesnt work then check resistance (Download the manuals from aeu86)
Stuttering could be bad ignition (I`ve had the same countless times on a 2T engine). My tip is if you want to know your engine then check everything. I.e check spark plugs for fouling, check cylinder compression (Doesnt matter how much/little compression, so long as all 4 cyl`s have identical comp levels), check spark gap on your plugs, check plug wires for voltage loss/resistance (stretch them when you check), check distributor cap for wear on the points inside, check distributor for oil leaks (Yes it can happen) which can explain sudden ignition failure, check rotor for wear. And last two things, check oil levels (doww) and check coolant in case it has oil in it (But if spark plugs all look the same you should be safe), easiest to tap the radiator into clean bucket, if its all good just pour it back into the radiator 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
03-17-2014, 04:06 PM
Hey Rascal.
I noticed that my coolant is very dirty. I will replace it soon. For the other stuff, Will look into it when i got the time. Just been to a anime con this weekend and still recovering haha Thanks for all the tips so far :wink: hopefully i will get it all fixed soon! Build your dreams. Ford Puma 1.7 Zetec-s Daily Toyota AE86 Levin Coupe "Jinxy"- Dreamcar Mitsubishi sapporo - bosuzoku project |
Digital Dash | evfan42 | 190 | 259,533 |
05-03-2024 06:44 PM Last Post: banpei |
Dash Waning Lights | pack | 7 | 4,167 |
10-06-2021 01:00 PM Last Post: pack |
Trueno Digital dash kph to mph | Bojack | 3 | 6,899 |
11-21-2018 12:27 AM Last Post: kazi |
Custom Dash Cluster | kazi | 14 | 19,884 |
10-24-2017 09:05 PM Last Post: kazi |
Dash Lights | kazi | 3 | 5,666 |
09-12-2017 10:04 PM Last Post: kazi |
