Filters for ITB BT 20V
01-09-2009, 11:34 PM
I need to buy some filters for my Blackie. Do you have any experiences with pipercross, kn, or some other brands?
Where did you buy them, and what is the price?
DRIFT.HR
01-31-2009, 06:55 PM
Instead of doing individual filters, maybe do the complete cover from ITG filters or Jenvey.
They work well (better than individual socks/k&n's) as they allow room for airflow to enter the stacks/bellmouths sideways, and can look awesome.
ITG - http://itgfilters.net
[Image: AEU86 AE86 - Filters for ITB BT 20V]
On a blacktop 20v, borrowed from here:
http://www.dorikaze.net/showthread.php?t=21271
Jenvey - http://www.jenvey.co.uk/
Andrew
02-01-2009, 02:54 AM
1 x BASE PLATE BLANK ALLOY (ITG-9JC40)
1 x ITG FILTER JC40-100 (ITG-JC40-100) or ITG-JC40-65
1 x ITG FILTER DUST SPRAY (ITG-JDR1)
Fitting advice
Selection of the filter element depends on the amount of
room available.
ITG recommend fitting the tallest element possible, though
a gap of 1/2” (13mm) average must be left over the top of
the filter for air to circulate.
If using ram pipes, there must be an absolute minimum gap
of 3/4” (19mm) or preferably 11/4” (32mm) between the end
of the pipe and the underside
of the top of the filter.
03-15-2010, 11:10 PM
BUMP!
any other ideas? i need an easy and preferably unexpensive solution.
uni sock filters maybe? experiences?
07-13-2010, 04:23 PM
the filter is not very expensive.
http://www.isa-racing.com/product_info.p...ement.html
ITG sell base plate w/o holes
but I'm preffer laser cut plate.
does anyone have a drawings of plate for 20v BT?
http://www.isa-racing.com/product_info.p...latte.html
owau no ka "I"
07-13-2010, 10:01 PM
I have the Pipercross filter, and its easy to use and easy to clean...
07-15-2010, 02:30 PM
I've used uni socks (the light-green ones).
When I had them on I've noticed a very big responce and power loss...
When you are using filter on velocity stack you must have a very large area...
  4A-GE 20V ITB bolt patterns kjb 7 14,687 02-27-2016 01:23 PM
Last Post: kjb
  How to install 20V ITB on 16V head Mr.komp 7 14,677 12-28-2015 05:35 PM
Last Post: pack
  Machining Pistons to run 20v head... And FCR's on a 20v? PazzaAE86 2 6,442 09-15-2013 01:08 AM
Last Post: jondee86
  20v itb inlet manifolds totta Crolla 24 32,418 12-14-2012 12:21 PM
  4AGE 20v ITB vacuum instructions on Intecracing.com JAVResistance 17 39,304 05-07-2011 05:50 AM
Last Post: jondee86
