Filters for ITB BT 20V
01-09-2009, 11:34 PM
I need to buy some filters for my Blackie. Do you have any experiences with pipercross, kn, or some other brands?
Where did you buy them, and what is the price? DRIFT.HR |
01-31-2009, 06:55 PM
Instead of doing individual filters, maybe do the complete cover from ITG filters or Jenvey.
They work well (better than individual socks/k&n's) as they allow room for airflow to enter the stacks/bellmouths sideways, and can look awesome. ITG - http://itgfilters.net ![]() On a blacktop 20v, borrowed from here: http://www.dorikaze.net/showthread.php?t=21271 ![]() Jenvey - http://www.jenvey.co.uk/ ![]() Andrew |
02-01-2009, 02:54 AM
1 x BASE PLATE BLANK ALLOY (ITG-9JC40)
1 x ITG FILTER JC40-100 (ITG-JC40-100) or ITG-JC40-65 1 x ITG FILTER DUST SPRAY (ITG-JDR1) " Fitting advice Selection of the filter element depends on the amount of room available. ITG recommend fitting the tallest element possible, though a gap of 1/2” (13mm) average must be left over the top of the filter for air to circulate. If using ram pipes, there must be an absolute minimum gap of 3/4” (19mm) or preferably 11/4” (32mm) between the end of the pipe and the underside of the top of the filter. " |
03-15-2010, 11:10 PM
BUMP!
any other ideas? i need an easy and preferably unexpensive solution. uni sock filters maybe? experiences? |
07-13-2010, 04:23 PM
the filter is not very expensive.
http://www.isa-racing.com/product_info.p...ement.html ITG sell base plate w/o holes but I'm preffer laser cut plate. does anyone have a drawings of plate for 20v BT? http://www.isa-racing.com/product_info.p...latte.html owau no ka "I" |
07-13-2010, 10:01 PM
I have the Pipercross filter, and its easy to use and easy to clean...
07-15-2010, 02:30 PM
I've used uni socks (the light-green ones).
When I had them on I've noticed a very big responce and power loss... When you are using filter on velocity stack you must have a very large area... ![]() |
4A-GE 20V ITB bolt patterns | kjb | 7 | 12,334 |
02-27-2016 01:23 PM Last Post: kjb |
How to install 20V ITB on 16V head | Mr.komp | 7 | 12,039 |
Machining Pistons to run 20v head... And FCR's on a 20v? | PazzaAE86 | 2 | 5,193 |
20v itb inlet manifolds | totta Crolla | 24 | 27,093 |
12-14-2012 12:21 PM Last Post: Bean |
4AGE 20v ITB vacuum instructions on Intecracing.com | JAVResistance | 17 | 34,465 |
05-07-2011 05:50 AM Last Post: jondee86 |
