Folding headlight of the Trueno
02-16-2007, 11:55 PM
Hello I converts my Levin straight to the Trueno now I have a problem can to me someone to say like the 5 cables to be occupy-attached have
02-17-2007, 12:07 PM
Banpei worked that out on his car, the levin wiring loom is missing a wire for the popup action of the lights, the light switch for a trueno is different aswell.
I think he fixed it by running an extra wire and attaching a separate switch. But I don't know the exact details, I'm sure he'll reply to this or else just send him a PM to ask him about it.
02-18-2007, 02:08 PM
if you are missing a cable, it looks like you'll need the trueno headlight switch, which is quite different from the levin. it has the option to keep the headlights "popped up" and turned of.
Probably that will save your problem. If you cannot get a trueno switch, then you'll maybe need an extra switch to activate it.
Pedro Velado
GT-S Owner
[Image: AEU86 AE86 - Folding headlight of the Trueno]
02-18-2007, 04:11 PM
Next to the switch the Trueno has a light retractor unit (some box containing relays which determine when to popup the lights). If you haven't got it you need to attach it to an extra switch instead.
I do have the unit (in my shed) but I'm just too lazy to sort out the wiring and I attached it to a seperate switch, which is much easier than doing it properly. Wink
See also this topic:
http://www.aeu86.org/viewtopic/wanted-he...eno/t/3717
  AE86 Headlight + wiper wiring (levin) bozu 11 16,751 09-19-2017 02:06 PM
  Trueno headlight help kazi 9 13,143 04-20-2017 09:37 AM
Last Post: kazi
  TRUENO - LHD headlight solutions pack 11 14,339 09-21-2016 10:29 AM
Last Post: pack
  Peculiar headlight issue - main beam Jezza_hr 3 6,069 10-04-2015 09:25 PM
Last Post: Jezza_hr
  LHD W.G (West Germany) wires from dimmer & dash switch to headlight relays? Rascal21 11 15,399 07-07-2014 09:16 AM
