Folding headlight of the Trueno
02-16-2007, 11:55 PM
Hello I converts my Levin straight to the Trueno now I have a problem can to me someone to say like the 5 cables to be occupy-attached have
02-17-2007, 12:07 PM
Banpei worked that out on his car, the levin wiring loom is missing a wire for the popup action of the lights, the light switch for a trueno is different aswell.
I think he fixed it by running an extra wire and attaching a separate switch. But I don't know the exact details, I'm sure he'll reply to this or else just send him a PM to ask him about it. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
02-18-2007, 02:08 PM
if you are missing a cable, it looks like you'll need the trueno headlight switch, which is quite different from the levin. it has the option to keep the headlights "popped up" and turned of.
Probably that will save your problem. If you cannot get a trueno switch, then you'll maybe need an extra switch to activate it. Pedro Velado GT-S Owner ![]() |
02-18-2007, 04:11 PM
Next to the switch the Trueno has a light retractor unit (some box containing relays which determine when to popup the lights). If you haven't got it you need to attach it to an extra switch instead.
I do have the unit (in my shed) but I'm just too lazy to sort out the wiring and I attached it to a seperate switch, which is much easier than doing it properly. ![]() See also this topic: http://www.aeu86.org/viewtopic/wanted-he...eno/t/3717 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
AE86 Headlight + wiper wiring (levin) | bozu | 11 | 16,547 |
09-19-2017 02:06 PM Last Post: banpei |
Trueno headlight help | kazi | 9 | 12,944 |
04-20-2017 09:37 AM Last Post: kazi |
TRUENO - LHD headlight solutions | pack | 11 | 14,226 |
09-21-2016 10:29 AM Last Post: pack |
Peculiar headlight issue - main beam | Jezza_hr | 3 | 5,999 |
10-04-2015 09:25 PM Last Post: Jezza_hr |
LHD W.G (West Germany) wires from dimmer & dash switch to headlight relays? | Rascal21 | 11 | 15,189 |
07-07-2014 09:16 AM Last Post: Ivan141 |
