For what is this connector
03-05-2013, 10:57 PM
fax0815 Wrote:I´m getting confused, does your switch open or close at a certain temperature? Hello fax, One thing is for sure the setup woks ![]() I use NC temp switch (OE toyota) and NC relais. Wityh NO relais it doesn't work. I made a quick electrical layout. I hope it's clear As you can see with IG OFF contact will be closed so direct supply from the battery will keep the fan running all the time. Or I need permanent power to the relais but it will empty the batt.also at the end. About the curent the fan is using... after hearing about impressive numbers up to 30Amps I measured the current myself: At start up it peaks until 8A. Afterwards it runs with around 4A. I fused it with 10A to be save and rapidly switch it on and off for several times ... fuse didn't blow. Now I use 15A fuse. I drove it (7°C outside) for several km's. after stationary running the engine for 5-10min. the fan turned on for <1min and switch off again. after 5min it switches on again for less than a minute. So I guess cooling is sufficient. ![]() Hopefully it will be the same in summer.... ![]() |
03-07-2013, 03:15 AM
Thanks, thats what drawings are there for, explaining things easy without to many words
![]() Looks like a 1,5mm^2 so it should be fine with 15A ![]() I´ve had a twin speed Kenlowe and if blew 30A everytime... 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
03-07-2013, 01:58 PM
fax0815 Wrote:Thanks, thats what drawings are there for, explaining things easy without to many words The initial plan was to put PACET in until I found this Corolla E10 Fan for 5euro ![]() ![]() ![]() On the other hand I do not drive it on track or races (only regularity rallies) so the E10 fan might do. I know, there is no need for an E-fan than but I just like building these kind of things |
which connector is this | ditn | 7 | 8,074 |
07-27-2015 11:24 AM Last Post: pack |
help, puzzled by the radio connector | Bean | 4 | 6,191 |
11-17-2014 11:32 PM Last Post: banpei |
the connector saga (please help everyone) | Bean | 8 | 9,594 |
06-23-2014 01:13 PM Last Post: Bean |
Help! Diagnostic connector (IGN) for dataloging with MS? | Bean | 2 | 4,559 |
05-24-2011 11:07 AM Last Post: roman |
Firewall harness connector?? | choco | 0 | 2,966 |
02-09-2008 04:00 PM Last Post: choco |
