Fuel pump and starter on the same relay
08-19-2008, 09:23 AM
hi
can i connect the fuel Pump and starter to one 5 pin relay switch
85 ground
86 ignition
87 battery
30 fuel pump and starter
08-19-2008, 11:09 AM
If the "starter" wire energises the starter solenoid, it won't work.
If the "starter" wire leads to a second set of contacts that close to
energise the starter solenoid, then yes, it will work Smile For example.
the second set of contacts could be a momentary contact "start"
push button, or the "start" contacts on the ignition keyswitch.
Cheers... jondee86
09-03-2008, 05:40 AM
The starter and fuel are not on the same relay, but on seperate circuits turned on in unison.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
09-03-2008, 07:10 AM
Search for parrots post with links to the Electrical Wiring Diagrams. Everyone who even looks sideways at their wiring should have one of these open next to them!
  20v BT - which oil pump? Mylesmck 4 5,901 06-21-2022 04:51 PM
Last Post: pack
  Fuel pump issue DJexor 11 11,406 04-29-2022 05:45 AM
  AE86 starter options max_ae86 12 38,539 07-28-2019 08:17 PM
Last Post: harkes
  Trunk and fuel door cable pack 2 9,651 04-23-2018 11:01 PM
Last Post: pack
  fuel line hose from the pump Wikizz 4 8,498 10-16-2017 07:11 PM
Last Post: jdm86gtz
