Fuel pump help
04-16-2008, 09:56 PM
How did you check for fuel at the injectors? Best way is to loosen the fuel line to the cold start injector and see if something comes out DURING cranking, this is important since the fuelpump only runs during starting and obviously while running.
Next check for voltage at the connectors to the fuel pump, if there is 12v there but your not getting fuel, then it's time to change the fuelpump. To do this, you need to take the fueltank off of the car. I know there are many stories about that procedure on the forum so do a search. FABRICA MI DIEM, PVNC! |
Messages In This Thread |
Fuel pump help - alex-evo - 04-16-2008, 09:28 PM
[] - Ivan141 - 04-16-2008 09:56 PM
20v BT - which oil pump? | Mylesmck | 4 | 2,582 |
Fuel pump issue | DJexor | 11 | 4,854 |
fuel line hose from the pump | Wikizz | 4 | 5,955 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
4age smallport oil pump in bigport engine? | ditn | 2 | 8,083 |
12-06-2014 08:10 PM Last Post: ditn |
Oil pump question | megabob | 2 | 4,862 |
03-05-2014 05:37 AM Last Post: oldeskewltoy |
