Oil pump question
03-03-2014, 11:52 PM
Oil pump question
I've only noticed after fitting my new oil pump from a silver top that it has an allen key for something what is it for? is it something to do with regulating the oil pressure
03-05-2014, 05:37 AM
Oil pump question
That is the plug for the passage from the pump housing out to the area where it makes a 90 degree turn into the block. The plug blocks off how they machined the outlet
Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
20v BT - which oil pump? | Mylesmck | 4 | 3,055 |
Fuel pump issue | DJexor | 11 | 5,780 |
fuel line hose from the pump | Wikizz | 4 | 6,260 |
4age smallport oil pump in bigport engine? | ditn | 2 | 8,416 |
12-06-2014 08:10 PM Last Post: ditn |
trans oil, lsd oil change | Apolan | 9 | 17,595 |
