Fuel pump - how to disconect?
03-25-2009, 03:13 PM
Does anybody now how to disconect EFi pump in engine department. Where are plus and minus wire for that. I want to put High flow -low pressure pump in engine department for carburetors, and just disconect EFi and reconect on new pump, without taking fuel tank down and do that.
Any sugestion?
http://www.driftclub.rs
03-25-2009, 04:45 PM
Don't do it because you will not have fuel.
Just put AE85 low pressure pump in the tank and block the return fuel line.
Simple, safe, effective.
If you really want to disconnect the EFI pump, just unplug the jack in the boot. It's 2 wire jack.
03-25-2009, 08:04 PM
I like that idea with AE85 pump, just to try find model for carburetors end just take fuel tank down and swap it. I hope that easy to find new one.
I read somwhere that stock Efi pump in AE86 is passive when it's unplug off power. That fuel can flow tru her with no problem, but mybee I read wrong. And that is the reason why I ask for,but if they realy can't working it's stupid to disconect on that way.
  20v BT - which oil pump? Mylesmck 4 3,074 06-21-2022 04:51 PM
Last Post: pack
  Fuel pump issue DJexor 11 5,859 04-29-2022 05:45 AM
  fuel line hose from the pump Wikizz 4 6,266 10-16-2017 07:11 PM
Last Post: jdm86gtz
  4age smallport oil pump in bigport engine? ditn 2 8,422 12-06-2014 08:10 PM
Last Post: ditn
  Oil pump question megabob 2 5,090 03-05-2014 05:37 AM
User(s) browsing this thread:
