Fuel pump options
04-01-2012, 09:40 AM
Fuel pump options
Hey guys just wondering which fuel pump is interchangeable with the AE86s
It's stock.
04-01-2012, 02:01 PM
Fuel pump options
a walbro wil do the job.
just ebay-it
daily driver avensis 2.0 d4d and Yaris 1.0
weekend driver 1985 AE86
04-01-2012, 05:44 PM
Fuel pump options
You don't need a big fuel pump, something near 100lph will do the trick just fine.
I think you can use one from honda car without modification (maybe the plug...)
Why do you want to change your pump by the way ?
For people who need a 255lph pump (if you don't have a big turbo setup with 250+ hp, you dont need this !) Bosch 040 is way better than a Walbro shit on ebay...
04-01-2012, 06:18 PM
Fuel pump options
Project D Wrote:For people who need a 255lph pump (if you don't have a big turbo setup with 250+ hp, you dont need this !) Bosch 040 is way better than a Walbro shit on ebay...
true but still overkill on almost any 4age.
just to put it in perspective a 100lph pump will suport 240hp easily and on top wont heat the fuel unnecessarily due to pumping silly amounts of it back to the tank.
04-01-2012, 06:57 PM
Fuel pump options
A decent rule of thumb on fuel pumps.... 1 liter can support 2.5 hp...... BUT That is without considering wear. IDEALLY... figure about 2hp - 2.2hp per liter when wear is part of the calculations
The stock oem fuel pump is about 84 lph
9 out of 10 people who own a Walbro 255.... are just plain idiots Thumbs up!
Dan -
04-01-2012, 09:05 PM
Fuel pump options
RX7 FC, Supra MA, MR2 etc etc.. most will fit with minor difficulties.
I used an FC pump myself when my original pump died.
04-01-2012, 10:53 PM
Fuel pump options
Bean Bandit Wrote:just to put it in perspective a 100lph pump will suport 240hp easily and on top wont heat the fuel unnecessarily due to pumping silly amounts of it back to the tank.
True on NA car, but on turbo you have to consider that the flow drop with the pressure. A little bit too big pump is always better than run lean on boost I think.
04-02-2012, 04:02 PM
Fuel pump options
If a stock pump makes 84l/h it is enough for about 200hp new. Could an engine loose a few hp becouse of a 27 years old fuel pump?
And BTW. Could I use a Honda S2000 pump in a stock AE86 petrol tank?
04-02-2012, 04:41 PM
Fuel pump options
Yes you can lose few HP if the pump have lost a lot of flow.
For 200hp I would upgrade the fuel pump, especially if it a 27 years old pump Tongue
The easy rule to size your fuel pump:
Flow of your injectors x number of cylinders x 0.06
(0.06 -> x60: minute to hour, /1000: cc to liter)
Exemple for a blacktop:
295cc @ 3bar
295 x 4 x 0.06 = 70.8 l/h
So the minimum flow of your fuel pump should be 71l/h @ 3bar
(Personally I prefer to add 20 to 30% to this number as a safe margin)
04-02-2012, 06:27 PM
Fuel pump options
Project D Wrote:Yes you can lose few HP if the pump have lost a lot of flow.
295cc @ 3bar
Well...I dont think fuel pump can still make that much after all these years...Big Grin Big Grin
  20v BT - which oil pump? Mylesmck 4 3,065 06-21-2022 04:51 PM
Last Post: pack
  Fuel pump issue DJexor 11 5,829 04-29-2022 05:45 AM
Thumbs Up ITB filter options mister86 1 3,630 12-06-2020 10:44 AM
  AE86 starter options max_ae86 12 31,380 07-28-2019 08:17 PM
Last Post: harkes
  AE86 rear suspension options 2018 Alex 9 11,583 01-24-2018 02:25 PM
