Fuell cell issues
10-15-2009, 08:51 PM
Fuell cell issues
[Image: AEU86 AE86 - Fuell cell issues]
I bought this fuell cell but after i unpacked it i found out i bought the wrong one because it doesnt have a return..
It has a filler, feed (blue) and vent(red) but i doesnt have a return Banging head
Now i was think to make a return in the filler neck but i dont know if this is possible.
i was thinking of drilling a hole in the filler neck, put a nipple in it and put the fuell return on it.
Will that work?
10-15-2009, 09:38 PM
Fuell cell issues
Should work just fine. If there's enough flat area on the filler neck adapter, you could ask someone with aluminium welding gear to weld one of these on the drilled hole for a clean AN-6 hose attachment.
[img name=]http://www.aeu86.org/files/su/sum_220060_w_352.jpg[/img]
10-15-2009, 10:20 PM
Fuell cell issues
yup Smile just do it Smile
If your going to refuel with the fuel pump on , make sure you point the nipple down, so it doesn't splash when you open the fuel cap.
  Running issues sam3007 6 2,962 06-26-2022 01:34 PM
Last Post: Dave W
  Over heating issues MIGGZFSU 12 11,943 05-11-2017 05:09 PM
Last Post: MIGGZFSU
  Shortshifter TRD - Issues pack 13 12,916 09-19-2016 10:57 PM
Last Post: jondee86
  20v Starting Issues mad.matt 10 11,871 09-24-2014 12:44 PM
Last Post: pack
  SR20DET (S13) gearbox shifting issues in AE86 heshan 8 11,424 07-22-2014 01:07 PM
Last Post: heshan
